FEnatic Posted June 14, 2005 Share Posted June 14, 2005 Do you guys reuse head bolts or are these supposed to be one time use, like so many of today's products? Quote Link to comment Share on other sites More sharing options...
fredtam Posted June 14, 2005 Share Posted June 14, 2005 I replace them each time I pull the head. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted June 15, 2005 Share Posted June 15, 2005 In consideration of expense, I would question how much metal fatigue has occurred in a set of L6 head bolts and ......how often...they should be replaced due to ordinary use or even occasional high speed efforts. I know around 1974 there was a spectacular difference in Datsun 4 cylinder head bolts to some very strong ones (that did not know how to break) identified by a slight circle indentation round the allen head hole. A record kept of head bolt torquing would indicate the need for replacement of the bolts needing attention. Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted June 15, 2005 Share Posted June 15, 2005 I only use the Turbo bolts, Nissan Comp sells them as high strength. They have the circle. I tend to change them every full rebuild. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted June 15, 2005 Share Posted June 15, 2005 I’ve rebuilt about a dozen Z car L-series engines and changed out an additional twenty some head gaskets over the last 30 years. I have always re-used the original head bolts unless one had corrosion damage (rust pitting) on it. I have never had a problem with a head bolt that has been re-used. In 1972 Nissan improved the strength of the head bolt and the new bolt was identifiable by a ring (or recess) around the top of the bolt. I would definitely change out any of the early head bolts with these later ones or the turbo head bolts. The turbo head bolts have a “13" stamped on the top of the head bolt and can the torque can be increased to 60 ft-lbs. However, I always install new rod bolts during a rebuild as the consequences of a failed rod bolt are far more severe than a “stretched†head bolt. Quote Link to comment Share on other sites More sharing options...
