Exhaust look
tfreer85
If you want dual exhaust you basically have two options: run both in the stock location (will have to clearance the spare tire well), or change the fuel tank. You don't have to use a fuel cell. I will be running my duals in the approximate location of your first link and I am using a nylon tank from an LS1 Trans Am. Dan Juday is running duals in approximately the same location as Bob_H's pic, and I believe he's using a tank from a Suzuki Samarai mounted on the passenger side.
It is a pretty common practice called "shaving" cut and weld in panels to cover holes and indents.
Here is my before;
http://www.desertzassociation.com/membersrides/Robert/75z/pic/pic5.jpg
during;
http://www.desertzassociation.com/membersrides/Robert/75z/pic/pic4.jpg
and the after;
http://www.desertzassociation.com/membersrides/Robert/75z/pic/pic8.jpg
