FEnatic Posted June 28, 2005 Share Posted June 28, 2005 Was looking at some Autometer temp guages, I really like the full sweep, but they are mechanical as oppsed to the electrical which are 90*. Are the mechanical just as accurate as the electrical, and do they justify the extra cost for them? thanks Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted June 29, 2005 Share Posted June 29, 2005 Your avatar is really distracting. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 29, 2005 Share Posted June 29, 2005 What engine/ trany are you running? for all the original transmissions that came with these cars had mechanical cable to the speedo (which you probably already know) to go electrical guages you need a sending unit and I don't think that autometer sells sending units. I've read somewhere that the the stock speedos were set about 5 mph faster than actual speed (45 on guage, btween 40-45 actual speed). because you can't really calibrate them, don't know about autometer mech guages though. Th electrical is for sure, but I don't think they make a speedo sending unit for the first gen tranies. Quote Link to comment Share on other sites More sharing options...
FEnatic Posted June 29, 2005 Author Share Posted June 29, 2005 I was actually looking to use the temp guages. Wasn't sure if one or the other is more accurate. The mechanical temp guages are more expensive than the electric ones. I suppose the electric ones would be easier to run due to smaller wires. Thanks about the avatar, sometimes I just gaze and th..... Quote Link to comment Share on other sites More sharing options...
Michael Posted July 1, 2005 Share Posted July 1, 2005 I'd go with mechanical. They're harder to plumb, but are more reliable; no worries about a broken sender unit or poor electrical connection. BTW some years ago there was a thread on the accuracy of Autometer water temp gauges. As I recall, they can be off by some 10 degrees at room-temperature boiling point (212 deg F). I ended up with mechanical temperature and oil pressure gauges from Suntune (sp?) - from Pep Boys. Yes, they're cheap and cheezy-looking, but they are full-sweep and the water temperature gauge is dead-on accurate. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 2, 2005 Share Posted July 2, 2005 I agree with Michael, I have run all Mechanical Autometer gauges and used braided steel lines with Earls fittings so no chance of getting hot oil or coolant inside the car. I do not like the teflon straw lines with the brass ferrels supplied with the Autometer gauges. Mechanical are more of a pain to install but definitely worth the effort. Here is mine: Yasin Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted July 3, 2005 Share Posted July 3, 2005 I would not call it distracting but mesmerizing. Not what the heck was this post all about anyway? J/K! Mike Quote Link to comment Share on other sites More sharing options...
Sumo Posted July 3, 2005 Share Posted July 3, 2005 What's mesmerizing? Quote Link to comment Share on other sites More sharing options...
AK-Z Posted July 3, 2005 Share Posted July 3, 2005 lol "bouncy" Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted July 4, 2005 Share Posted July 4, 2005 yasin are those the autometer ultra lights? Quote Link to comment Share on other sites More sharing options...
