akeizm Posted July 1, 2005 Share Posted July 1, 2005 Hey all, I got my z running with a turbo setup and I installed a walbro 255lph pump. Now I knew this was gonna be a noisy sucker but didnt know it was that loud! I have put the padded sleeve on it but I'm wondering if there is a way to reduce the noise? Can I box it in with some insulation or will that make the pump overheat? Thanks, Marc. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 1, 2005 Share Posted July 1, 2005 Are you using the Walbro GLS392 pump? Mine is CONSIDERABLY quieter than stock, and is one of the least noisy pumps I've ever heard. I mounted it externally using the padded sleeve and clamps... Also if you mount an intank version of this pump externally it will be louder and will overheat... don't ask me how I know this. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted July 1, 2005 Share Posted July 1, 2005 sound deadening blankets.. Maybe DynoMat.. that sound deadening material they use for car stereo's and stuff.. Quote Link to comment Share on other sites More sharing options...
260DET Posted July 1, 2005 Share Posted July 1, 2005 Mounting them on rubber insulators helps too, in fact don't they sell some sort of quiet kit which includes such insulators? Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 1, 2005 Author Share Posted July 1, 2005 Hmmm I was thinking of getting a plastic box (water and dust proof) and lining it with a fire resistant fabric. Then bolting the pump in there to shut it up. I have a 3" exhaust with 1 muffler @ the end and the pump at idle drowns that out. But I think it is the GLS392. I guess If I cant get it quiet enough I'll have to get another one, cause it will drive me insane. Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 4, 2005 Author Share Posted July 4, 2005 Well I'm going to get myself a new pump. Anyone have some suggestions on what would flow just as much as my walbro but be alot quieter? Quote Link to comment Share on other sites More sharing options...
Nigel Posted July 4, 2005 Share Posted July 4, 2005 What do you have the pump mounted to? If it's sheet metal, it'll likely be noisy because the sheet metal will vibrate and amplify the sound. I mounted mine to my custom rear cross member behind the differential (used to clear the LSD fins). It's a welded steel piece. When the car is running, I can barely hear the pump. And I even cut away some of the sleeve around the pump for better cooling. Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 4, 2005 Author Share Posted July 4, 2005 True, I was also thinking of relocating it but wasn't sure it would make a difference. But yea I have it mounted to the piece of metal the stock carb one was mounted to. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 5, 2005 Share Posted July 5, 2005 Thats exactly what I did as well with mine, and it isn't very loud at all... way quieter than the stock bosch turbo pump. Strange. Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 5, 2005 Author Share Posted July 5, 2005 I'll have a make a recording of it. I'll prolly do it tommorow, cbf'ed right now. Quote Link to comment Share on other sites More sharing options...
dot Posted July 5, 2005 Share Posted July 5, 2005 On my pump I used a six inch section of braded line before and after the pump. The thought was that the noise was being transmitted through the solid fuel lines and into the frame rails and surrounding body area. The pump already had a sleeve and mount insulators. It all works quietly now. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 5, 2005 Share Posted July 5, 2005 I have the external GSL392 as well and mine is super quiet...you can bearly tell that it is running. Yasin Quote Link to comment Share on other sites More sharing options...
wheelman Posted July 5, 2005 Share Posted July 5, 2005 I've found that when my GSL392 is having to pull the siphon it's much noisier. Based on where you mounted yours, above the tank, I think it's always trying to pull a siphon and consequently is noisy. Try mounting it lower and see if that helps. Wheelman Quote Link to comment Share on other sites More sharing options...
Pyro Posted July 5, 2005 Share Posted July 5, 2005 That is right wheelman! I found the same thing. If the pump is having trouble pulling gas from the tank, it will make a bunch of noise. It will vibrate the front fenders!! Lower the pump to the bottom of the tank first and if it still makes noise then check for a semi-clogged output line from the tank. Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 5, 2005 Author Share Posted July 5, 2005 Didnt think of that. Its not mounted really high but its a little higher than the tank. I might mount it horizontal and low. I'll get onto that this weekend. Edit: Here is the pump I got. And was from these guys also http://www.extremepsi.com/store/customer/product.php?productid=17175&cat=561&page=1 Quote Link to comment Share on other sites More sharing options...
akeizm Posted July 9, 2005 Author Share Posted July 9, 2005 Sorted out the noise. The instructions didnt state the pump needed to be mounted horizontally. Quote Link to comment Share on other sites More sharing options...
