eds240z Posted September 25, 2013 Share Posted September 25, 2013 Thanks for the reply! I'll check the charging system tonight. By the way I'm running a internal voltage regulator alternator if that matters. Also I've been doing more research and I found some people added a diode or resistor. I haven't done this. So I'm reading up on it but I don't see where I need to add this. Quote Link to comment Share on other sites More sharing options...
Apollyon12 Posted October 5, 2014 Share Posted October 5, 2014 This fix also works with the tach signal from an L28et Quote Link to comment Share on other sites More sharing options...
madkaw Posted April 14, 2015 Share Posted April 14, 2015 So I am looking at this solution for my set-up. Running MS3 with LS1 coils on an original 71 current tach. The directions from Turbo6inKY above says to hook the black/white stripe up to a 12 volt ignition source. But originally the black/white going to the tach was hooked to a 12volt ignition source, so why not use this right?. Maybe over thinking this, but want to be sure. Quote Link to comment Share on other sites More sharing options...
eds240z Posted April 14, 2015 Share Posted April 14, 2015 I tried using the msd tach adaptor 1st and didn't work. I found an old thread that said to use a 280z tach with modification and it worked. Here's the link good luck!! http://forums.hybridz.org/topic/66137-how-to-modify-a-280z-tach-to-work-with-msd-for-free/ Quote Link to comment Share on other sites More sharing options...
THUNDERZ Posted May 5, 2016 Share Posted May 5, 2016 So....you are saying that this approach isnt right? Dan,I checked the wiring on my '72 this weekend. Here's what I've got:Black/white wire(previously coil +) connected to red wire from tach adaptor.Green/white wire connected to swithed +12V.I hope this helps.graemlins/cheers.gif Don Quote Link to comment Share on other sites More sharing options...
jacky4566 Posted May 26, 2017 Share Posted May 26, 2017 Bumping this thread a bit but I wanted to add. For people with older Current sensing tachs and 6x coilpacks you can simply pull the power from the old distributor terminal. The tach will sense the current draw on the COPs. Worked fine for my toyota 1zz coils. I learned this of course after i had already wired them all on a separate line haha. Quote Link to comment Share on other sites More sharing options...
Rice Posted August 14, 2025 Share Posted August 14, 2025 This thread is ancient so I'm just posting in case others come along in search of a solution. If you install the MSD 8920 as indicated by the OP and the tach only reads 200 rpm, here is what fixed it for me. At issue, reverse the wires to the tach. Connect B/W wire to red going to the 8920 and connect G/W to 12V switched. After this my tach was happy. 1 Quote Link to comment Share on other sites More sharing options...
