The ONLY way to appreciate 315's... (NO 56k)
Finally have all four on the ground and thought I'd show them off! Now I just need to get the flares figured out.
Specs on the wheels/tires:
Rear -- 17 x 11 CCW Classics with 315/35's
Front -- 17 x 10 CCW Classics with 275/45's
wow! holy wow!
what flares are you going with??
not sure zg's will fit but looks awesome
very nice! have any more pics?
how about from the front down the side ? and straight on the front?
how much does the front stick out?
whats the backspacing?
Guest ON3GO
looks great.
tell me about the studs!
i was gonna do that to my green Z with the CCW's that are on there now but i desided to do it to my blue Z.
mike
how about from the front down the side ? and straight on the front? whats the backspacing?
Here's the closest I have:
The rears have a 5.75" BS and the fronts are 5.25".
The front wheels extend out ~1.25" past the original fender lip. The rears... 3".
Have you decided on what flares you are going to run?
I was going to run VB flares, but they're not wide enough. I'll probably have to make something custom.
Wow. OMFG nice wheels now I see why the Steel VB Street Flares are no good. So one could assume that the VB Steel Street Flares when they say are 3" wider than stock they might be meaning in total ie 1.5" each side. Good luck with the custom flares - what style? ZG A or the ZG B? or somethink different again?
Here is a pic of the ZG B flare.
I'd love to have a set of flares like that (ZG B).
The problem with the VB's is that they ARE 3" wider... but they're 3 inches wider from the top of the flare (where the body side changes direction away from the arch). So they're actually ONLY 1" wider than the original arch lip. I created a rant post with some pictures... here ya go: VB Flare Thread
you sure ZG's wont fit? i have the same size you have and my ZG's fit..
mike
Mike... you have 17 x 11's in the rear with 5-3/4" BS and the ZG's fit? These suckers stick out 3"... I thought the ZG was only good for 2 - 2.5"? :confused:
Guest ON3GO
ya.. same back spacing but i have 275's in the rear for a streched look.
they fit, maybe with ur tires no.. but its worth a shot to check.
mike
Those do look wicked. Do you run coilovers?
Yep, Ground Control Units. Even with the rotor hat in place (which is 3/8" thick) I had to trim the lower perch a bit. Not much though... it actually clears without trimming... but only by 1mm or so.
Heh' date=' you are building the car around the wheels--that's like something I would do
Wheels cost more then the car!!!!!!!!!!!!!!!!!!!!!!
[/quote']
At this point the wheels do cost more than the car did!
CRAP CAKES that looks MEAN!!! WOW....I hope you are complimenting the look with some hp to turn those barrels you have on the rear.
Looking forward to updates.
Yasin
Lol! Eh... 400-500 to start.
