Zhadman Posted July 17, 2005 Share Posted July 17, 2005 Finally have all four on the ground and thought I'd show them off! Now I just need to get the flares figured out. Specs on the wheels/tires: Rear -- 17 x 11 CCW Classics with 315/35's Front -- 17 x 10 CCW Classics with 275/45's Quote Link to comment Share on other sites More sharing options...
Guest Nikolai Posted July 17, 2005 Share Posted July 17, 2005 Nice. Quote Link to comment Share on other sites More sharing options...
v8dats Posted July 17, 2005 Share Posted July 17, 2005 wow! holy wow! what flares are you going with?? not sure zg's will fit but looks awesome very nice! have any more pics? how about from the front down the side ? and straight on the front? how much does the front stick out? whats the backspacing? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 17, 2005 Share Posted July 17, 2005 looks great. tell me about the studs! i was gonna do that to my green Z with the CCW's that are on there now but i desided to do it to my blue Z. mike Quote Link to comment Share on other sites More sharing options...
Guest Vince Posted July 17, 2005 Share Posted July 17, 2005 Man that is gonna look tough! Im dying to get some wide meats for my z, the 245's just arent cutting it.... Quote Link to comment Share on other sites More sharing options...
Jsquared Posted July 17, 2005 Share Posted July 17, 2005 Freaking A. Quote Link to comment Share on other sites More sharing options...
Thumper Posted July 17, 2005 Share Posted July 17, 2005 I don't think those are wide enough:twisted: Makes my 245's seem seem like skinnies. Nice looking. Have you decided on what flares you are going to run? Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 17, 2005 Author Share Posted July 17, 2005 v8dats said: how about from the front down the side ? and straight on the front? whats the backspacing? Here's the closest I have: The rears have a 5.75" BS and the fronts are 5.25". The front wheels extend out ~1.25" past the original fender lip. The rears... 3". Thumper said: Have you decided on what flares you are going to run? I was going to run VB flares, but they're not wide enough. I'll probably have to make something custom. Quote Link to comment Share on other sites More sharing options...
Sparky Posted July 17, 2005 Share Posted July 17, 2005 wow, thats alot of meat under there! looks viscous! Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted July 17, 2005 Share Posted July 17, 2005 Those do look wicked. Do you run coilovers? Douglas Quote Link to comment Share on other sites More sharing options...
DavyZ Posted July 17, 2005 Share Posted July 17, 2005 Heh, you are building the car around the wheels--that's like something I would do Wheels cost more then the car!!!!!!!!!!!!!!!!!!!!!! Davy Quote Link to comment Share on other sites More sharing options...
NZeder Posted July 17, 2005 Share Posted July 17, 2005 Wow. OMFG nice wheels now I see why the Steel VB Street Flares are no good. So one could assume that the VB Steel Street Flares when they say are 3" wider than stock they might be meaning in total ie 1.5" each side. Good luck with the custom flares - what style? ZG A or the ZG B? or somethink different again? Here is a pic of the ZG B flare. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 17, 2005 Share Posted July 17, 2005 you sure ZG's wont fit? i have the same size you have and my ZG's fit.. mike Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 18, 2005 Author Share Posted July 18, 2005 I'd love to have a set of flares like that (ZG . The problem with the VB's is that they ARE 3" wider... but they're 3 inches wider from the top of the flare (where the body side changes direction away from the arch). So they're actually ONLY 1" wider than the original arch lip. I created a rant post with some pictures... here ya go: VB Flare Thread Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 18, 2005 Author Share Posted July 18, 2005 Quote you sure ZG's wont fit? i have the same size you have and my ZG's fit.. mike Mike... you have 17 x 11's in the rear with 5-3/4" BS and the ZG's fit? These suckers stick out 3"... I thought the ZG was only good for 2 - 2.5"? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 18, 2005 Share Posted July 18, 2005 ya.. same back spacing but i have 275's in the rear for a streched look. they fit, maybe with ur tires no.. but its worth a shot to check. mike Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 18, 2005 Author Share Posted July 18, 2005 ZROSSA said: Those do look wicked. Do you run coilovers? Yep, Ground Control Units. Even with the rotor hat in place (which is 3/8" thick) I had to trim the lower perch a bit. Not much though... it actually clears without trimming... but only by 1mm or so. Quote Heh' date=' you are building the car around the wheels--that's like something I would do Wheels cost more then the car!!!!!!!!!!!!!!!!!!!!!! [/quote'] At this point the wheels do cost more than the car did! Quote Link to comment Share on other sites More sharing options...
NZeder Posted July 18, 2005 Share Posted July 18, 2005 ZG-B replica flares are made by some companies in Japan still. Here is a link to one that I know of. Arita Speed Aero Catalog - Japanese or try this Arita Speed Aero Catalog - English Here is a pic of a car with their kit installed. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 18, 2005 Share Posted July 18, 2005 CRAP CAKES that looks MEAN!!! WOW....I hope you are complimenting the look with some hp to turn those barrels you have on the rear. Looking forward to updates. Yasin Quote Link to comment Share on other sites More sharing options...
Zhadman Posted July 18, 2005 Author Share Posted July 18, 2005 Quote CRAP CAKES that looks MEAN!!! WOW....I hope you are complimenting the look with some hp to turn those barrels you have on the rear. Looking forward to updates. Yasin Lol! Eh... 400-500 to start. Quote Link to comment Share on other sites More sharing options...
