Phyxius Posted August 6, 2005 Share Posted August 6, 2005 I was thinking about this... It would be cool to have a quick-remove shifter. That along with the stock wheel lock would make it much harder to steal... Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 6, 2005 Share Posted August 6, 2005 Hmmm, neat idea. One catch is to have a shifter stay strong enough...so how would the mechanism work and be up to par??? The idea is good, but I wonder what the execution would be like. Also to consider would be the shift boot and getting past that---it might be an issue if the detaching mechanism is inside the boot. Still the idea is intriguing. Davy Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 6, 2005 Share Posted August 6, 2005 I had a teacher in school show us just how easy it is to break the stock wheel lock mechanism. All he had to do was turn the wheel really hard and it broke. It was a late model Chevy of some sort(I cant remember what model though). So the wheel lock is hardly an anti theft device. It would be pretty hard to drive though with out a stick to shift with! That with a quick release steering wheel would be great! Guy Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 7, 2005 Share Posted August 7, 2005 Not a bad idea. A pair of vice grips will steer a stolen car, but the theif might be totally unprepared for no shifter. Plus having a shifter come off while driving is not the safety issue a steering wheel would be. Would also be smart to leave it in reverse instead of first. Not sure how one would go about making a quick disconnect shifter that would be easy to reconnect and not be easily circumvented by just using a long screwdriver. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted August 7, 2005 Share Posted August 7, 2005 Just put a hidden shut off switch on the fuel pump, no gas no run. There was a guy that I talked to with a 911, carbed model, that was stolen more than once. He put a locking shut off valve in the fuel line. It was stolen again but was found in the middle of the street in front of his house. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted August 7, 2005 Share Posted August 7, 2005 ya definatly dont park in 1st then.... Why not a kill switch? but neet idea! Quote Link to comment Share on other sites More sharing options...
Phyxius Posted August 7, 2005 Author Share Posted August 7, 2005 I wasn't really suggesting it for practical use... I just thought it was an interesting idea Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted August 7, 2005 Share Posted August 7, 2005 At least here in the NYC area, it needs to be flat-bed proof. My friends Z was stolen and recovered a week later with the hidden kill switch still in the off position. It probably did 40-50 miles but never ran once. lol. Removing the stick shift is a good idea. The more tricks you pull the less chance of getting stolen. I still like that beat-up-citation car cover from that car commercial...albeit computer generated. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted August 7, 2005 Author Share Posted August 7, 2005 how about a device that engages all 4 brakes when you flip a hidden switch? Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 7, 2005 Share Posted August 7, 2005 how about a device that engages all 4 brakes when you flip a hidden switch? I dont know about your car but the brakes will not hold my car! Too much HP/TQ! Although it would slow them down! Guy Quote Link to comment Share on other sites More sharing options...
Sparky Posted August 7, 2005 Share Posted August 7, 2005 well, why not cut the shifter off at the base, weld on some threaded tubing and the thread the shifter base, then you could simply unscrew the shifter and easily slide it up and out of the boot. the offset shifter might be tricky to maneuver at first, but once you get the hang of it, it should be a snap. all and all its an idea...and every little bit you can do will help prevent theft, although if somebody wants your car, they will take it no matter what. Quote Link to comment Share on other sites More sharing options...
