Confused Posted September 1, 2005 Share Posted September 1, 2005 My mom just sent this to me: Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 2, 2005 Share Posted September 2, 2005 horrible i'm definetly going to need a daily driver (nothing short of 93 octane is going to feed my baby) Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted September 2, 2005 Share Posted September 2, 2005 y may i ask do you need 93 octane on your car. I run my N/A ZX on 89 and i never hear a ping. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 2, 2005 Share Posted September 2, 2005 The turbo z I don't have yet will probably never see that low octane gas. well, maybe 89. but...I don't know. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted September 2, 2005 Share Posted September 2, 2005 well what year turbo z are you going to be usuing. Im pretty sure none of them require 93 octane not even the 350z, and if the car is set up to run on 89 octane i think you suffer when jumping to 93 with out timing changes, im not sure but i believe this is true because the 93 octane gas takes longer to burn then the 89. Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted September 6, 2005 Share Posted September 6, 2005 unless you plan on turning up the boost a bit there is no reason to run higher octane. Quote Link to comment Share on other sites More sharing options...
Zhadman Posted September 6, 2005 Share Posted September 6, 2005 I can't run my WRX on anything lower than the piss 91 here in CA. It pings and retards timing enough... going lower would probably not be a good idea for me. So that's one example of why someone would use 93 octane. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 6, 2005 Share Posted September 6, 2005 apparently you only need that high octane if you're "turning up the boost" xD Quote Link to comment Share on other sites More sharing options...
Zhadman Posted September 6, 2005 Share Posted September 6, 2005 apparently you only need that high octane if you're "turning up the boost" xD Perhaps I'm confused. Are you referring to any turbocharged car (stock boost and modified boost levels) or are you only referring to turbocharged cars with higher than stock boost levels? My WRX is bone stock... and will ping and retard on a warm day. Pre-ignition (detonation) is most definately related to engine load AND fuel octane rating. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted September 6, 2005 Share Posted September 6, 2005 what do you get for mileage out of your WRX? Quote Link to comment Share on other sites More sharing options...
Confused Posted September 6, 2005 Author Share Posted September 6, 2005 All I know from my friend Sean, is that he hasnt seen boost in a week in his WRX. He drives like a grandma and shifts as 2500 all the time now. I think he said something in the range of 18-22 MPG. I dont remember correctly. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted September 6, 2005 Share Posted September 6, 2005 I know a guy who's got an '02 Wagon and he gets about 18. I also know a guy who's got an '05 STi who gets about 13. Quote Link to comment Share on other sites More sharing options...
Confused Posted September 6, 2005 Author Share Posted September 6, 2005 13 Jeebus thats terrible. Id rather have a 396 Nova. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted September 6, 2005 Share Posted September 6, 2005 that's bad...when a 396 nova gets better gas mileage than your car xD Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted September 6, 2005 Share Posted September 6, 2005 well what year turbo z are you going to be usuing. Im pretty sure none of them require 93 octane not even the 350z, 350Z requiires premium fuel. Quote Link to comment Share on other sites More sharing options...
Confused Posted September 7, 2005 Author Share Posted September 7, 2005 350Z requiires premium fuel. Correct. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted September 7, 2005 Share Posted September 7, 2005 Well my 280Z 'requires' premium fuel now too. It just refuses to run on regular, or even the mid-grade. Ping pop bang fart.... Quote Link to comment Share on other sites More sharing options...
