violacleff Posted September 13, 2005 Share Posted September 13, 2005 I forgot to take the fill plug off while the tranny was out. Now its impossible to get it off. Is this a possible alternate way? Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted September 13, 2005 Share Posted September 13, 2005 It is no fun and very messy, but possible as I have done it too Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 13, 2005 Share Posted September 13, 2005 Isn't there a higher plug in the tranmission? I've never used anything other than the actual fill plug but I would swear I remember somebody using something else. Reverse light hole maybe??? Quote Link to comment Share on other sites More sharing options...
Synlubes Posted September 14, 2005 Share Posted September 14, 2005 I just use a piece of plastic tubing and a funnel. Install the drain plug Run the tube (about 4 feet) thru the rear fender well down to the fill whole in the diff Pour in the first quart and just measure the amount needed from the second quart Install fill plug It takes a few minutes but it’s clean Works for the tranny also Quote Link to comment Share on other sites More sharing options...
auxilary Posted September 14, 2005 Share Posted September 14, 2005 Use the reverse signal plug hole. It's 1/2" below the tranny filler hole, so if you jack up that side of the car where the hole points out of by about 3" higher than the left, you can get a good fill with appropriate amount of tranny fluid. I had to do that with the 5 speed I got (albeit that 5th gear would never stay in gear, so that was a pointless purchase, and I felt ripped off). The drain filler plug wouldn't budge under anything... 4 foot breaker bar, impact gun, etc Quote Link to comment Share on other sites More sharing options...
violacleff Posted September 14, 2005 Author Share Posted September 14, 2005 Dangit! I was going to do the reverse light, since I broke the wires anyway, but something didn't seem right about it! Anyway, my somoan z brother around the corner came over and got it right off! I took the drain plug off my last tranny and installed it as a fill plug for this one. In the future I can use a 1/2 in breaker instead of a 17 wrench. BTW I got her running again last night. Quote Link to comment Share on other sites More sharing options...
orklc Posted September 14, 2005 Share Posted September 14, 2005 You could also remove the shifter and fill the transmission from the top in a very comfortable manner. Take note of the capacity of the unit from the Nissan manual and do not over fill. You could also go to a quick lube 10 minute oil change location and let them be the one having to take the oil fill plug off and fill up. It is probably the simplest and probably not too expensive. Good luck. KC Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 15, 2005 Share Posted September 15, 2005 Dangit! I was going to do the reverse light, since I broke the wires anyway, but something didn't seem right about it! Anyway, my somoan z brother around the corner came over and got it right off! I took the drain plug off my last tranny and installed it as a fill plug for this one. In the future I can use a 1/2 in breaker instead of a 17 wrench. BTW I got her running again last night. Another little trick which is too late to help you but might help someone else is to use a 19mm 12 point socket on the square plug. Fits right on then you can use a breaker bar or long ratchet on that or even just double wrench it. Quote Link to comment Share on other sites More sharing options...
Synlubes Posted September 15, 2005 Share Posted September 15, 2005 Wrench made by Hazet Has 4374 stamped on it 14mm / 17mm 8 point socket ends Both ends rotate I purchased this years ago off a tool truck It works great for the drain plugs Quote Link to comment Share on other sites More sharing options...
auxilary Posted September 15, 2005 Share Posted September 15, 2005 Another little trick which is too late to help you but might help someone else is to use a 19mm 12 point socket on the square plug. Fits right on then you can use a breaker bar or long ratchet on that or even just double wrench it. Mine wouldn't budge either way> I wound up completely rounding off the plug edges. (fill plug). I had to fill it through the reverse light Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 16, 2005 Share Posted September 16, 2005 Yours sucks Alex. Quote Link to comment Share on other sites More sharing options...
auxilary Posted September 16, 2005 Share Posted September 16, 2005 lol, don't have a Z tranny anymore, waht do I care? Quote Link to comment Share on other sites More sharing options...
scorreia Posted September 19, 2005 Share Posted September 19, 2005 Wrench made by HazetHas 4374 stamped on it 14mm / 17mm 8 point socket ends Both ends rotate I purchased this years ago off a tool truck It works great for the drain plugs That would be nicer if it were 6 feet longer. I had to take the transmission out of the car to remove mine. I brought it down to the shop and after whacking at it with an air hammer, then a chisel, the guy finally found a 6ft or so bar that he had to hang on to break it loose. Clearly I need a lift in my garage.... Why, oh why, is that fill plug such a bitch? Quote Link to comment Share on other sites More sharing options...
