Guest sukimoto Posted September 28, 2005 Share Posted September 28, 2005 pretty soon i will be upgrading the suspension on my z. These are the only coilovers i have found so far. http://www.modern-motorsports.com/catalog/product_info.php?cPath=26_40&products_id=66 they dont show a spring rate though, so will they stiffen up my ride? or should i just go with some struts/shocks + stiff springs? also, i was wondering if the 70-78z coilovers http://www.modern-motorsports.com/catalog/product_info.php?cPath=26_40&products_id=12 would work on my car with a little work Quote Link to comment Share on other sites More sharing options...
Dragonfly Posted September 28, 2005 Share Posted September 28, 2005 After looking at the link you provided I can assume that you have a 280zx. After reading the first couple of lines this is what I saw "one pair of Hypercoil's unrivalled quality coilover springs selected to suit your requirements". What that statement means to me is that when you talk to them they will help you to determine what your needs are and provide you with the correct spring rates. This is exactly what would be expected of a profesional operation and a profesional operation is what you will be dealing with when deal with Modern Motorsports. Dragonfly Quote Link to comment Share on other sites More sharing options...
nullbound Posted September 28, 2005 Share Posted September 28, 2005 What that statement means to me is that when you talk to them they will help you to determine what your needs are and provide you with the correct spring rates. This is exactly what would be expected of a profesional operation and a profesional operation is what you will be dealing with when deal with Modern Motorsports. Agreed. Ross will help you determine the appropriate spring rates based on what you are using the car for. Quote Link to comment Share on other sites More sharing options...
Guest sukimoto Posted September 28, 2005 Share Posted September 28, 2005 thank you both Quote Link to comment Share on other sites More sharing options...
tickwon Posted September 28, 2005 Share Posted September 28, 2005 Yeah, you have to talk to Ross at modern motorsports. I have a set of his coil-overs for my 280ZXT. I bought them about three years ago. Talk him and he'll set you up with the right spring rates. Mine are 200lbs front and 225lbs rear. Here's some pics: Chris Quote Link to comment Share on other sites More sharing options...
Guest sukimoto Posted September 29, 2005 Share Posted September 29, 2005 i only see the rear coilovers on the site Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted October 18, 2005 Share Posted October 18, 2005 thats why you have to call him/ email him to request a full coilover set. Something I will do in the future. Tickwon- how stiff does your car ride- stiffer than a 350Z? do they really eliminate the "squat"? Quote Link to comment Share on other sites More sharing options...
tickwon Posted October 18, 2005 Share Posted October 18, 2005 It does eliminate a lot of the "squat". It is a little stiffer than the 350Z IMO. Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted October 18, 2005 Share Posted October 18, 2005 awesome. Do you autoX. Would you reccommend stiffer springs for someone wanting to autoX and drift? The Z is stiff, but I kinda like the bone jarring ride so maybe 225lbs front and 250lbs rear? Quote Link to comment Share on other sites More sharing options...
tickwon Posted October 18, 2005 Share Posted October 18, 2005 I have Tokico Illuminas all around adjusted at the stiffest settings. I like to auto X, but drifting is what I love to do as a hobby to mess around. Going with a stiffer spring would be the way to go with a drifting and even auto-x setup. With my set-up...you get a jarring ride. Watch the guys who drive the touring cars...watch how their cars jar around...that's what mine looks like going fast around corners, gripping like it's on rails. Change the tires and I'm ready to slide around. It's fun! Chris Quote Link to comment Share on other sites More sharing options...
73hls30 Posted October 19, 2005 Share Posted October 19, 2005 ground control set-up with 275 front and 325 rear springs give hardly any squat, but is stiff. i also have 275-40-17 front and 315-35-17 rear, which will give the car a stiff ride anyhow. i have heard of people removing the rear swaybar with springs over 275 to help with your goals. definately move the front struts to the rear and install the mr2 front struts as suggested. koni's are too stiff, tokiko's seem to work out the best, kyb will have you utilizing their warranty as long as you don't mention the car is lowered.... and if your wondering, this car does not drift at all. which is just the way i set the car up for how i like to drive. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted October 19, 2005 Share Posted October 19, 2005 Talk with ross about struts as well... You can get custom valved Konis for your setup. If you're sectioning the strut, make darned sure to follow John C.'s write-up... I disagree with the above comment about Tokicos. I've got a brand new set with one already failed unit... And they ahve only been used to roll the car around in the shop... Illuminas seem to be ok for street use and AutoX... Dont' plan to use them in road race or HPDEs. Most guys I know who have generally don't keep them... They tend to not be able to shed heat well and end up failing in the valving chamber. MIke Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted October 20, 2005 Share Posted October 20, 2005 thanks for the FYI Quote Link to comment Share on other sites More sharing options...
johnc Posted October 20, 2005 Share Posted October 20, 2005 Tokico Illuminas that are used in Z applications (Z, MR2, Rabbit) do not have enough rebound control for spring rates over 250 lb. in. When you go to springs that stiff, or higher, you need to start moving into modified Konis, AD, and Bilstiens. For 99% of the people on this board, 250 lb. in. springs are plenty. 200 front and 225 rear (or vice versa) are ideal with a set of Tokicos. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted October 20, 2005 Share Posted October 20, 2005 Will the 200/225 springs with Tokico's Illuminas on setting 1 be stiffer than stock or similar to the factory ride quality? Just curious... Quote Link to comment Share on other sites More sharing options...
johnc Posted October 20, 2005 Share Posted October 20, 2005 About twice as stiff as stock. Quote Link to comment Share on other sites More sharing options...
