AK-Z Posted October 12, 2005 Share Posted October 12, 2005 Since the RB26dett uses a transfer case to transfer the power to the front wheels, can't you just remove the front drive shaft and swap oil pans to have it RWD? is the transfer case a "locked" transfer case or is it a "differencial" type? Quote Link to comment Share on other sites More sharing options...
jsap Posted October 12, 2005 Share Posted October 12, 2005 Isn't that how every body is doing the RB26dett swap into the Z or 240sx? Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted October 12, 2005 Share Posted October 12, 2005 The popular method is to use the RB25DET tranny. Some guys have adapted the ZXTT 5 spd tranny.Then, a few guys are running the GM automatics. I don't know anything about the GT-R tranny. Quote Link to comment Share on other sites More sharing options...
rztmartini Posted October 13, 2005 Share Posted October 13, 2005 Hey AK-Z. do you know what the color is to those cars in your sig? Quote Link to comment Share on other sites More sharing options...
stony Posted October 13, 2005 Share Posted October 13, 2005 I guess you could do it that way but you would have to somehow plug the area that the front shaft comes out of. prabably be cheaper to just go with a gtst tranny. to do it that way would be jury rigged in my opinion Quote Link to comment Share on other sites More sharing options...
stony Posted October 13, 2005 Share Posted October 13, 2005 AK-z we still need to get together sometime...i would like to check out your car. Quote Link to comment Share on other sites More sharing options...
cheftrd Posted October 13, 2005 Share Posted October 13, 2005 You can remove the driveshaft and you will have to plug the hole. Power feeds directly through the transfer, to the rear wheels. There is a clutch-pack similar to that of an automatic that, when applied, sends power to the front. Otherwise, it's the same as a conventional rwd set-up. You cna even take the guts out of the transfer to eliminate any paracitic losses. You may have trouble with the transfer interfering with the tunnel. Quote Link to comment Share on other sites More sharing options...
Nismo180 Posted October 13, 2005 Share Posted October 13, 2005 RB26Dett has the front diff inside the oil pan. Transfer case is part of the transmission. RB25 oil pan and transmission(both bolt right up) and it's just like a RWD setup. Just need to get your driveline right. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted October 13, 2005 Author Share Posted October 13, 2005 rztmartini said: Hey AK-Z. do you know what the color is to those cars in your sig? Sorry I don't know the name I just changed the hue from a burgendy. stony said: AK-z we still need to get together sometime...i would like to check out your car. Yeah I know. I thought you stopped by at one point, but I was out. The cars are in really rough shape even though the glass is still good. I just asked because I was looking at pictures of the AWD trany and wondering that from the size of the tranfer case that would have a any form of rear/front power transfer. Quote Link to comment Share on other sites More sharing options...
cheftrd Posted October 14, 2005 Share Posted October 14, 2005 People here are starting to use the 26 trans because the FR 33 one is getting rare. 26 trans' are everywhere; you can't give them away, especially the 32 version. Nissan doesn't make the syncros for this box anymore, so when overhauling, you must upgrade to the 33 syncros and first three gears on the main. $$$ Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 14, 2005 Share Posted October 14, 2005 Hi Matt, please tell me what the "fr 33 " box is? thanks joel cheftrd said: People here are starting to use the 26 trans because the FR 33 one is getting rare. 26 trans' are everywhere; you can't give them away, especially the 32 version. Nissan doesn't make the syncros for this box anymore, so when overhauling, you must upgrade to the 33 syncros and first three gears on the main. $$$ Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted October 14, 2005 Share Posted October 14, 2005 Probably Front/Rear as in front engine, rear drive? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 14, 2005 Share Posted October 14, 2005 Ahh... then that would be the same as I have now... JAMIE T said: Probably Front/Rear as in front engine, rear drive? Quote Link to comment Share on other sites More sharing options...
