bluesinged Posted October 26, 2005 Share Posted October 26, 2005 On the way home in my 280ZXT, I often hit speeds around 80-90mph because no one else is on the roads around where i drive and who wants to be on an empy road for an hour doing 50mph... thats just boring. The drive is around 25 miles and wastes a ton of as because on stock gears 85mph is roughly in the range of 3200-3500rpm... I'd love some recommendations as to what gears i might be able to replace mine with as I start building my new one... stock gears just anger me now... gas prices own me =( (a friend of mine suggested 84 300ZX gears... i dont know if this is possible or how much it would cost, but i'm interested into looking at that option if the gears are set to handle higher speeds @ lower rpms...) Oh, it's a manual transmisson 1981 280ZX with a cross between an N/A motor and Turbo top end that i need the gears for... if that makes a difference. -JC Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted October 26, 2005 Share Posted October 26, 2005 well if its an 81 you prob have the r200 geared 3.90, you could swap to a 3.54 or i think there is a 3.36 Quote Link to comment Share on other sites More sharing options...
Forrest Posted October 26, 2005 Share Posted October 26, 2005 If it was a 5spd NA 280zx that you turbo'd, you should have a 3.9 rear - get a 3.54 from 81-83 auto or turbo car, or any 280Z. Quote Link to comment Share on other sites More sharing options...
bluesinged Posted October 26, 2005 Author Share Posted October 26, 2005 The rear diff i have on the Z I'm currently driving is a 1983 280ZX Turbo... THAT is the one thats reving up so high in 5th... i was thinking of getting gears or really anything for decent mileage while highway cruising. Is it possible to just swap out 5th so i can keep my low gear acceleration? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 26, 2005 Share Posted October 26, 2005 Well then, you just cut your options to almost zero... I doubt you'll find the 3:36 R200 diff, so your only hope is the trans you have is the 79-82 nissan 5 spd (IIRC), that way you can get the 82-83 nissan 5 spd which has a better freeway 5th gear. The rear diff i have on the Z I'm currently driving is a 1983 280ZX Turbo... THAT is the one thats reving up so high in 5th... i was thinking of getting gears or really anything for decent mileage while highway cruising. Is it possible to just swap out 5th so i can keep my low gear acceleration? Quote Link to comment Share on other sites More sharing options...
2126 Posted October 26, 2005 Share Posted October 26, 2005 Another easy solution is to run slightly taller tires (larger O.D.), as long as they fit without rubbing. Quote Link to comment Share on other sites More sharing options...
bluesinged Posted October 27, 2005 Author Share Posted October 27, 2005 So, stock tires on a 280ZX turbo were 195/65 15's right? using the calculator posted here --> http://www.geocities.com/z_design_studio/transmission.html Oops... time to recalibrate my speedometer... i'm runnig 225/60 15's TY everyone i'll post if calibration was the problem. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted October 27, 2005 Share Posted October 27, 2005 Stock tires on the turbos were 205/60/15... Quote Link to comment Share on other sites More sharing options...
bluesinged Posted October 27, 2005 Author Share Posted October 27, 2005 Stock tires on the turbos were 205/60/15... Thanks for posting that, I honestly didn't know that =/ Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted October 28, 2005 Share Posted October 28, 2005 Just what kind of gas mileage are you getting? On my '82 280ZXT, I average in the low-mid 20's, which is a pleasant surprise to me since it's pretty close to my NA 280ZX. Quote Link to comment Share on other sites More sharing options...
