Strange L6 head find
RB26powered74zcar
I was browsing the Yahoo Japan site and came across this... any coments??
>> This was the broken english used to discribe it...<<
L type and the argon head combustion room processing being completed for the L6, being unused, to the aerodynamic volume displacement, if the meting face research it does, you can use directly. With 0.6 - 0.7 mm surface researches with 38cc. If it is 3.1l specification, it reaches compressed 11.5 rank, compression 12 is with the 1mm surface research. Valve 46 - 38, the valve guide turtle possession, the seat ring for the ベリリュウムレース, seat cutting is SPL cutting of the ナプレックセット long adjusting. If you can appoint combustion room capacity, the surface research it does with 此 one. If (it is fee separate) desired successful bid price, the surface research doing with 此 one, we send. Being with the same head form 330 PS or more to have put out with the K cam, you can guarantee efficiency. When you think of that it makes from one whether cheap you think. As for the mirror surface finish we ask with the successful bidder!
Yes that IS some Pro work right there boys ! It appears they refer tho using back gas or purge gas for the ports while fill-welding the chambers etc. Then that it has a 11.5 compression ratio without a 1mm headgasket.....12.0 if you DO use it.OR....perhaps the amount to be resurfaced or milled off the combustion face.Best I can tell........they are offering this as a service NOT as a HEAD for sale. They refer several times to the differences or optional steps and the change made from this as well as the fee's.
Killer NA head for the proper cam for certain.
Vinny 8)
