$15,xxx usd Exhaust...
J__
daaayaaam!! this is one expensive exhaust! but it's worth the money imo.
eisenhaus/eisenmann makes some of the best exhausts for euro cars. click on the gallerie link and listen to the video clips of the lambo contach and the ferrari f355...... sounds sweeeeeeeeeeeeett omgomg i just soiled myself... droooooooooool
http://www.eisenhaus.com/ehprice.php?selMake=9&selModel=4440&selSub=407&selPerf=2&selTip=1249%232.827%23none.gif&Submit.x=41&Submit.y=11
and look at those welds!!!
edit: is it possible to make a Z sound like that without putting in a ferrari engine? lol (f1 sound?)
I don't understand why it has so many bends welded together. Why not just use mandrel bender.
Because true mandrel bending equipment is very expensive:
http://www.vansantent.com/2060EX.pdf
And most equipment cannot handle bending Ti. Its really tough stuff and will gall unless the tooling used is either cadium plated or has other, more sophisticated coatings.
You'd think for that much money a mandrel bender would be a given. I wanted to buy one a while back until I found out how much they cost. I was thinking that picture was just a demo of their welding ability and not how they actualy build the stuff.
What about the inside? Does it come out that smooth? If there are still breaks on the inside it isn't as free flowing. Seriously, I think its for people with more money than sense or if you are building a car for somebody else and they are paying for it.
  • 4 weeks later...
Hand welding Ti is a pain too. You can only TIG weld it and Ti becomes magnetic when you run a current through it like while TIG welding so it wants to draw the filler rod in when you don't want it to, plus needs to be cryo treated because of dissimilar densities of bead to base metal.
I don't know where you got your information about welding Ti, but its all wrong. I've welded Ti many times and:
1. It does not become magnetic when welding current is applied.
2. You can weld Ti using GTAW, GMAW, Friction, Resistance, Laser, and Electron Bean processes.
3. And only the Metastable beta alloys (Ti-3Al-13V-11Cr, Ti-11.5Mo-6Zr-4.5Sn, Ti-8Mo-8V-2Fe-3Al, Ti-15V-3Cr-3Al-3Sn, and Ti-3Al-8V-6Cr-4Zr-4Mo) need post weld treatment.
Try these resources:
http://www.timet.com/fab-p27.htm
http://www.stainless-steel-world.net/titanium/welding.asp
http://www.key-to-metals.com/Article28.htm
Oh sorry. I thought that was the case from exp, but my dad has some weird setup in the shop. he attached a electro-magnet under the table. I've only been welding alluminum and titanium on it. I thought the weird electro-feild noise was coming from the welder.
My bad.:D
