Tutorial: SR Gearbox onto L-series engine
thehelix112
SR gearbox onto L tutorial
Parts Required:
L6 gearbox
SR gearbox
New L6 gearbox countershaft bearing (optional) Part Numbers: 63/22C3, TMB3/22C3, or 22BC0655X. Call CBC (http://www.conbear.com).
Specific Tools Required:
16mm drill bit
Dremel with a small grinding disc.
Optionals: 16mm H7 reamer bit, 41/64ths drill bit.
Step 1:
Remove L6 bell housing from gearbox. To do this unbolt the bolts halfway on the gearbox that go from the extension housing through the sandwich plate to the bell. Also unbolt the cover on the inside of the bell that the clutch arm sits on.
You will then need to remove the circlip on the front of the input shaft bearing. Use circlip pliers and a screw driver.
Put everything aside as you will be using some of it again.
Remove SR bell housing from gearbox following the same procedure.
Step 2:
Remove the SR countershaft front bearing using two chisel point screw drivers to get it started, then lever it off against the bearing (as opposed to the gear) so you don't ruin the gear.
Step 3:
Reinstall the 240Z countershaft bearing. Either reusing the one from the L6 box, or a new one. Gently knock it down with a rubber mallet.
Step 4:
Drill out the 1st/2nd selector shaft hole in the L6 bell housing using a 15 or 16mm drill bit then a 16mm H7 reaming bit. Or you could try a 41/64ths bit if you happen to have one lying around (thats what I ended up using).
Step 5:
Get a dremel/rotary tool and grind away 1mm or so from the countershaft casting on the inside side of the gearbox bell housing. This is necessary as the casting has been modified between the 71B and the 71C to accommodate the wider gears assumedly.
You also need to put a chamfer on the edge which is square standard. I made this chamfer between 1 and 2mm big.
Step 6:
Trial fit this bell onto the SR gearbox being careful of the oil supply cup on the upper passenger side just above the 1st mainshaft gear. Rotate the input shaft by hand. If it is very difficult to turn you need to die grind some more off the countershaft casting in the bell.
Step 7:
When you can bolt the gearbox up and rotate the input shaft easily you are just about ready to bolt the box together.
You could possibly have trouble with the 1st/2nd input shaft not wanting to go into the bell housing because this metal doesn't have any oil sitting on it, I suggest you squirt a dab in there. If the selector doesn't go in it can slide backwards (engaging 1st gear).
If this happens and the gearbox shifter is not in the 1st position you won't be able to select any gears (except 5th/Rev) from then on. If putting some oil in the 1st/2nd selector shaft hole doesn't solve the problem, you can put the gearbox in the 1st position before you bolt it up and it will be fine. Worked for me atleast.
Step 8:
Reassemble the gearbox as you took it apart and you're ready to go. Don't forget the circlip on the mainshaft bearing. Use the L6 front gearbox cover, clutch arm and throw out bearing carrier.
Additional issues:
The SR gearbox has the bolts for the gearbox x-member around 35mm further back than the 71B box. Depends on your car what you do to fix this. Here is what I did, tad dogey, but it works.
This gearbox is also 50mm longer at the end of the tailshaft. I took a tailshaft that was used on a 71B box and had it shortened by 50mm and it fits just fine (after you remove the cover for the front spline as it doesn't fit into the gearbox).
Big thanks to Mad1600 for helping me and motivation. :)
Pics to follow.
Dave
Perfect timing, nice write up! I pulled the bellhousing of an S14 box just the other day. I'm thinking about machining the countershaft bearing hole larger on the L-bellhousing rather than swap in the smaller L box bearing.
Any other known issues? Does the reverse light sensor still work OK?
Look forward to the pics.
Cheers,
Rob
The reverse light sensor is in the right place as far as I can see. Only the 1st/2nd selector fork is bigger, and even then only by 2mm, the other selector shafts are in the same place so the sensors will work.
You will need either an electronic speedo or a mechanical speedo drive though. I haven't bothered as yet but let us know if you find out what suits different setups.
Can definitely machine the bell to fit the bigger bearing. Simpler for backyarders like myself to just replace the bearing though.
Dave
The tranny in question is the FS5W71C that was used on a few different Nissans worldwide over the years with some slight variation in ratios.
Commonest 1st gear seems to be 3.321, in the UK however the S13 200SX (fitted with the CA18DET) has a 3.592 1st which is a bit mad.
You can also get aftermarket gear sets such as OS Giken which have closer ratios i.e. 1st is available as 2.717 or even 2.596.
There's quite a bit of useful info on this box here:
http://www.phattransmissions.com/transmissionParts.html
Cheers,
Rob
  • 3 weeks later...
So Follow Me on This One, Guys:
If the SX Gearbox is 2 to 2.5" longer than the original Z box.
And the differential Relocation of the Pre-71 cars is about the same...
Shouldn't you be able to use one of the early pre 71 driveshafts in the back of the SX tranny to mate with a differential in the "late location" without having it modified?
Reason for asking? I did three or four differential relocations for people and have those old driveshafts laying around for the day they want to "return the car to original and I can charge a premium for the parts because everyone else threw them away" (Or that's what I tell the wife!)
If this is the case, heck, I got the trannies, and I might have the driveshafts to boot! WOO HOO!
Looks like SX / KA tranny shiftlever relocation is about where the early trannies were shiftlever wise, too!
Anyone, Bueller?
turbobluestreak,
I just had the tailshaft shortened by 50mm (2"). The tranny mount I'll take a picture of next time I'm at the car. Its basically two bits of flat, one which goes to the transmission, the other to the x-member, then join them with two small bits of metal. No rubber mounting but there is rubber in the x-member to chassis connection and it appears to be just fine.
Tony D,
Yes the shifter is in the same spot. No changes there. You may THINK you have to beat the flare at the bottom of the stick to clear the hole, but thats only because your engine is leaning backwards because you forgot to chock it up after you got the gearbox out :redface:
Dave
  • 5 months later...
Does anyone have pics or clear diagrams of the 3 types of 5 speed L series boxes (FS5W71A, B or C). I have just bought a 5 speed box that is supposed to be from a Aussie 240Z and want to fit it to my MR30 Skyline hatch.
I think it is a 'B' box and have tried to match it to the diagrams in my manuals but there is just not enough detail 4 me to be entirely sure. I do know that mine is different to the one Lurch 2461 has picked up for his PNS R30 Skyline (his speedo output is on the left, mine is on the right as viewed from the rear).
Thanks
Wardie
  • 1 year later...
Guest JasonDMX2
I have a fs5w71c and the factory service manual does not correctly identify my synchronizer hubs so I have no idea how they go. Any help/pictures of your fs5w71c tranny internals would be appreciated.
They both have the right angle cutout on one face, but then on the other face one is chamfered and the other is flat.
Now it the manual they show the 3rd and 4th hub as having the cutout and chamfer on the front side and the back is also chamfered.
Then the 1st and 2nd hub has a right angle cutout on the front with a chamfer on the rear face.
Also, just to make sure they do refer to the "front" of the tranny as the motor side of the tranny, correct?
