280zx 5 lug drilling template?
knock out 3 of the 4 studs, then bolt up the rotor onto the axle, when you redrill for 5 lugs, you will actually only have to drill 4 holes, one remains on an existing stud, and you drill new holes where the other 4 holes line up... You can drill them yourself, but be sure that you have the holes exactly centered and you are drilling completely perpendicular to the flange... If you don't have a drill press, drill press vise, number drills etc... then you may need to take them to a machine shop....
also read these posts:
http://forums.hybridz.org/showthread.php?t=96240&highlight=drill+axles
http://forums.hybridz.org/showthread.php?t=70267&highlight=drill+axles
http://zcar.netdojo.com/5lug.htm
Hey David,what year zx are you working on? The above tech. works, but you should really use the drill press to drill,when you go to tap for studs the tap will follow a bad hole the same as a straight hole, this is how I done my first set of 280zx axles.Moser Engineering will drill, tap, and sell you 1/2" studs for $90.00.If you are working on a 82-83, than you can use the 300 rear set-up and that is 99% bolt in. not near as much work as my earlier thread on my '80.
Im working on a 79 :). Where is Moser? Im interested in sending my stuff to them if the work is quality.
you can easily drill them yourself IF you make a center punch and have the starting point accurate..
pop out 3 studs- use a new rear rotor and bolt it on tight with a nut-
use a machine shop type centering punch that fits the rotor exactly- we used to supply those with 5 lug conversion we sold-
mark it - and drill it in 4 steps or so-- use 7/16" ARP studs
  • 6 months later...
Excuse my ignorance I am only new to these things...
My car has the original 4 stud wheels & discs on the front
On the rear someone has put solid discs, presume from a 280ZX?
I have been researching bigger & vented discs for the front & whether to upgrade the rear to vented discs as well.
I have from my GTR R32 halfcut, 4 pot calipers and 297mm vented discs on 5 stud hub. I also have I think a Z31 rear vented disc setup & calipers.
Can I use the GTR front setup & the Z31 rear setup with 5 studs, or is there complete differences in the hub/stub axle setup?
Below are discs I have researched which seem close to the correct size, but what about the stub axle etc - am I better to stay with the 240Z set up and change them to 5 stud or can I bolt on Z31 front & rear stub axles?
Can anyone advise?
Front Rotors
CAR
DBA No
DIAM
ORIG HT
ORIG THICK
CENTRE HOLE
BOLT HOLE
WEIGHT
BEST
MATCH
COST
240Z
324
271
52
12.7
81
4
5.5kgs
Valiant CL, CM 1976-81
203
282
56.5
25.4
78
5
7kgs
7
GTR R32
4926
296
54
32
68
5
9.0kgs
GTR V Spec
4928
324
53.75
30
68
5
9.5kgs
300Z Z31
907
280
54
26
68
5
8.5kgs
300Z Z32
909
280
54
30
68
5
6.9kgs
350Z
954
296
49.2
24
68
5
7.6kgs
350Z Track
4600
324
49
30
68
5
R34 GTT
42304
310
53.75
30
68
5
BMW 320D E46, Z3 1999 on
979
286
51.6
22
79
5
7kgs
6
BMW 325 E46 2000on
966
300
52
22
79
5
6.7kgs
5
Ford Explorer 2000 on
864
305
56.5
26
82
5
8.6kgs
4
BMW 330i E46 2000on
2855
324
52
25
79
5
2
BMW M3 E36 1992-5
984
315
52.5
28
79
5
7.9kgs
3
BMW M3 E46 2001on
42850
324
52.5
28
79
5
8.8kgs
1
Toyota Hi Ace
767
285
46
28
84
5
8kgs
Rear Rotors
CAR
DBA No
DIAM
ORIG HT
ORIG THICK
CENTRE HOLE
BOLT HOLE
WEIGHT
BEST
MATCH
COST
280ZX
601
269
69
10
68
4
5.5kg
300ZX
605
290
47
10
68
4
Merc 220 to 65
251
279
72
10
67
5
4
Statesman 92/93
026
279
67
10.5
70
5
Sigma 80-87
207
280
73
10.5
68
4
3
Infinity G50 93on
923
292
64
9
68
5
Volvo S70 97on
883
295
72.5
10
68
5
1
Volvo 240 74-93
381
281
73.5
9.6
68
5
2
BMW 730 77-79
972
300
68.5
12
75
5
977
300
68.1
10
75
5
676
280
68.1
10
75
5
BMW 728 82-86
674
284
68.1
10
75
5
