Cruez Posted May 25, 2006 Share Posted May 25, 2006 Any more progress ??? I have CAD at home and could draw up the plans for you if you need them..just send me all the measurements... Let me know.. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted June 17, 2006 Author Share Posted June 17, 2006 http://pg.photos.yahoo.com/ph/larryjohnson97438/album?.dir=a576 I ordered 24 adjusting plates to be plasma cut yesterday and should be ready next week. Hopefully I will get back on this project. I will get some pictures out on the new cut adjusting plates when I recieve 'em http://pg.photos.yahoo.com/ph/larryjohnson97438/album?.dir=8223&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 17, 2006 Share Posted June 17, 2006 cool. I have been waiting forever... Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted June 19, 2006 Share Posted June 19, 2006 Cool Larry! Been watching your progress on this since you started. Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted June 20, 2006 Author Share Posted June 20, 2006 Photos of plasma cut camber adjusting plates http://pg.photos.yahoo.com/ph/larryjohnson97438/album?.dir=8223&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos The camber plate holes for the UB Machine monoball housings are (.015) undersize to allow a shoulder to be turned on the housing for more strength when welded to the camber plate (these pictures later). The top of the strut tower will have to be trimmed to allow the adjusting plate to slide (pictures later)....more camber photos........http://pg.photos.yahoo.com/ph/larryjohnson97438/album?.dir=a576 Quote Link to comment Share on other sites More sharing options...
Cruez Posted June 23, 2006 Share Posted June 23, 2006 I will be putting the ZX strut assemblies on my 510... Will this fit the bill also... (cause I gotsa have some when they go in) also.. where did you get your threaded tubes ?? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 23, 2006 Share Posted June 23, 2006 510 strut tops are much different and require a larger plate. Good news is you can adjust farther too because there's more room. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted June 23, 2006 Share Posted June 23, 2006 also.. where did you get your threaded tubes ?? yeah... when I looked at those pictures, I wondered the same thing, and are they big enough to fit over a 280 strut? Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted June 23, 2006 Author Share Posted June 23, 2006 The plates were designed to fit only the 240-280 Z without welding with a slight cut out at the top of the strut tower.. and have camber adjustment only - no castor adjustment. The monoball and attaching nut are only for the 240-280 z style strut cartridges and stock height strut tubes. The adjusting plate goes on top of the strut tower and the U shaped attachment plate goes on the bottom of the strut tower. Use of the plates should lower the the car at least two inches since the strut mounting insulator is not used and discarded. I plan to use 12 inch adjustable coilovers. This design can be modified to fit the 510 by the fabrication of a larger adusting plate and lower attachment plate. Quote Link to comment Share on other sites More sharing options...
datfreak Posted February 10, 2009 Share Posted February 10, 2009 old thread--this is really interesting stuff any progress? Quote Link to comment Share on other sites More sharing options...
iHeartTouge Posted March 1, 2009 Share Posted March 1, 2009 he hasnt logged in since June, i doubt we will be hearing from him. Quote Link to comment Share on other sites More sharing options...
