oil pump shims
Silent
What pressure are you running now? And what do you hope to achieve wit increased pressure? There is no real benefit with higher pressure. (there may be a slightly higher flow but not that much) The way that the oil film protects bearings has very little to do with pressure (as long as it is reasonable) and more to do with the oil! and high flow pumps will only work with an engine with loose clearences to help dissapate heat.
Chuckie:twisted:
Chuckie:twisted:
when cold
65-80 psi
when warm, 36-39 psi at 3k rpms
idle when warm 11 psi
lookin to raise the psi a tad bit, nothing extreme
HI Again' date='
Just insert a flat washer the same size as the O/D of the pressure spring between the spring and the regulator cap nut it that Easy. But If this doesn't raise the pressure then the pump has run out of flow with hot oil?
Chuckie:twisted:[/quote']
right on
thanks man!
HI Again' date='
Yes, I find that the standard M6 flat washer fits nicely!
10-15psi at idle is more than enough at hot idle.
The crappy stock oil pressure sender is a likely culprit for low oil pressure problems as well. A test with a mechanical gauge might be in order, it's reassuring to know that the pressure that the gauge is showing has some relationship to reality.
my crappy stock gauge reads zero, how ever, my elec aftermarket gauge reads 11 at idle
