Worried about balance
jmark06
I have a 240mm flywheel that I plan to have lightened and put on my turbo motor. When I called the machine shop they said that in order to balance the flywheel after lightening that I had to break the whole engine down. I've attempted to rebuild the engine mostly by myself b/c of money issues. I did not have the crank turned or balanced and now I'm worried that might be a problem but it wasn't out of tolerance when I pulled it. Am I in trouble now (I kept the same pistons and everyting, just changed bearings and had the head reworked) and can the flywheel be balanced without the rest of the engine?
The shop asks you to bring the internals to them so they know how much material to remove from the flywheel. They are not going to balance your internals. You bring home the very same crank/rods that you gave them.
You can't balance a flywheel without the rest of rotating assembly unless the rotating assembly is internally balanced. THEORETICALLY, without taking the engine apart, you can balance a new flywheel using the original flywheel as a reference(make the new and old equally off balance). BUT you must know the original mounting position of the old flywheel relative to crank or it's useless.
....THEORETICALLY, without taking the engine apart, you can balance a new flywheel using the original flywheel as a reference(make the new and old equally off balance). BUT you must know the original mounting position of the old flywheel relative to crank or it's useless.
Since there's no positioning dowels on Z L6's (right?), then would that apply?
If you marked both the crank and flywheel when they came apart then you have the information. Theoretically you can couple two flywheels together and balance them. That'll give you two equally unbalanced flywheels. However if you mention this method to your machine shop they'll just hate the idea. They don't have a perfectly balanced, correct size spindle to rotate the couple with, they don't have perfectly balanced, correct size fasteners to couple the flywheels. It is just easier to give them the crank/rods etc.
I am going to balance the whole thing in my L28ET because I use a diesel crank.
You don't need to pull your crank to have a flywheel balanced. It would be no different than putting a flywheel from another L on your car. They are balanced seperate from the engine. Just like your wheel and tire is balanced seperate from the hub. HKS sold flywheels that were balanced. They never required a crank sent in.
From my point of view, I will be using L24 rods and diesel crank, internal balancing never happened in my scenario.
Yes, you'll need to balance that, but as Clifton just mentinoed, you zero balance the crank/rods/pistons and then zero balance the flywheel seperately.
You DO NOT want to balance them as a unit - specifically to avoid the scenario where you have to rebalance the crank whenever you change the flywheel (or the clutch for that matter).
...zero balance the crank/rods/pistons and then zero balance the flywheel seperately...
Guess I was wrong about the flywheel balancing. There was a lot of material removed from the flywheel I have so I thought the flywheel must have been balanced with the internals, since the flywheel itself is a even disk.
Do I have to match the counterweights of the crank to the weight of the rods/pistons? Because I am contemplating lightening the crank, maybe even drill the crank pins. Either way I would like to get the crank as light as possible. Thanks
So they machine shop should just be able to lighten and balance it by itself? What do I tell them, that the engine is "already balanced internally"? I don't want to sound like I don't know what I'm talking about when I go over there and he tells me he doesn't recommend it.
Your situation reminds me of one I had. I lightened a Maxima flywheel and I wanted it balanced. The machine shop could not balance it separately. Why? Well the reason is they needed something to bolt it to. A crankshaft works very nicely.
The balancing procedure is to first balance the crank separately, then bolt on the flywheel and re-balance. I had a spare crank so I was able to balance the flywheel. Maybe this what your machinist is talking about.
If they are just lightening it, I dont see how it can get out of balance in the first place. I mean, they are just going to stick it on a lathe or mill some material off the back, right? either way, a uniform amount of material is going to be taken off the entire circumfrence of the flywheel, unless this is jim-bobs machine shop and he is out back with a die grinder........
Thats like having to "re-balance" a brake rotor after having it turned. Not necessary because it is removing a uniform amount of material everywhere on the disc.
Tell the machine shop that all L-series engines are internally balanced and dont need a flywheel to balance them out. Most engines that do not have a counterweighted crank are american engines and ALSO have dowel pinned flywheels.
Well I called the machine shop today told him I had an inline 6, nissan 280zx engine that was internally balanced, could he balance the flywheel by himself. He said he would research it and then I called him back a few hours later when he said I need the crank, rods, damper, and flywheel. What should I do, he seems to think that it's not possible without the rest of the engine but several here say it is?
  • 1 month later...
I am in a similar situation as you. I'm doing an L28 setup and the engine shop wants me to bring in the flywheel and clutch assembly so they can balance it to the internals. I thought this was the way it's done, but after reading this thread I'm not so sure now. However, the shop I'm using, Lesco, is very reputable. Jon Mortonson from Hybridz had his L series done there I think, so I guess I will just trust them. According to Lesco having the flywheel and clutch assembly balanced to internals just allows the engine to spin that much more freely, but it also seems I would not have to hard press my Lesco guy to leave that part out if I just wanted to save some money.
Just go for it, I bet you'll be stoked either way. And this forum is so technical it's easy to keep second guessing youself that you'll spin out of balance ;)---Hope this helps.
I agree that all of those pieces should be balanced, just not as a single unit. Zero balance the crank and then zero balance the flywheel/pressure plate separately. This way if/when you get a different clutch, you won't mess up the balance of the engine.
I am on the same boat as those guys told by their shops to "bring in everything" for a balance job. The shop I went to was a very reputable shop that has been around for some 50+ years and they said I should bring in everything for the balance job after I told them about the whole "I6 is internally balanced" story. Maybe what the shops were after is a level of finer balance higher than that of the stock job.
