280Z28 Posted February 11, 2006 Share Posted February 11, 2006 I sent him a message about the diff brace as well as some other things:) Quote Link to comment Share on other sites More sharing options...
Lengeo Posted February 11, 2006 Share Posted February 11, 2006 IRS. The diffs are lighter' date=' stronger and can be found for $100 with an LSD. Gears are also cheap.[/quote'] Any idea what applications and years use these LSD diffs? The ice is melting at the U-PULL-IT yard. Len Quote Link to comment Share on other sites More sharing options...
Moridin Posted February 11, 2006 Share Posted February 11, 2006 Any idea what applications and years use these LSD diffs? The ice is melting at the U-PULL-IT yard. Len I know the Cobras have them for sure, but some Tbirds and IRS Explorers may have a LSD too. Just be careful, because the 8.8's run very hot on road courses and you will lose the effectiveness of a clutch type LSD when that happens. If you want the good stuff, go with the 03/04 Cobra and upgrading to a helical style LSD (Torsen T2, T2R, or Detroit Locker True Trac) with a diff cooler. You'd be suprised how cheap you can get stuff from a guy that wants to put a solid axle in his IRS equipped Mustang. The 03/04 Cobra has bigger half-shafts and 31 spline axles as opposed to the 28 spline (maybe 29) of the older ones. Quote Link to comment Share on other sites More sharing options...
Moridin Posted February 11, 2006 Share Posted February 11, 2006 IRS. The diffs are lighter' date=' stronger and can be found for $100 with an LSD. Gears are also cheap.[/quote'] If you're interested, I'll post some pics of my parent's 03 Cobra rear-end when I redo everything with it in the next few months. Quote Link to comment Share on other sites More sharing options...
silicone boy Posted February 12, 2006 Share Posted February 12, 2006 Wow, those look too nice to put on a car. They belong in an art museum Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted February 14, 2006 Share Posted February 14, 2006 Just got an email from dave. he told me $349 for the brace set. Quote Link to comment Share on other sites More sharing options...
buZy Posted February 15, 2006 Share Posted February 15, 2006 Wow looks really cool I really like it but... I like to question things. To be bold and study this more not to offend feelings, just positive conversation here. Could more structure be added underneath or in front of the finned cover closer to the rear arm pivot points? Make a piece to join the two smaller clamps. If so the sway bar brace could be made lighter then. If possible this lower structure could have dual exhaust pipe cresents for clearane that would look cool. To share the loading of the bar and pivots now in one mount up higher with less dimensional span I wonder if the rigidity is that of stock datsun. Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted February 15, 2006 Share Posted February 15, 2006 Ok, so riddle me this ...... Can the braces be used with the stock mustache bar until enough money is raised for that too???? Quote Link to comment Share on other sites More sharing options...
Guest iskone Posted February 15, 2006 Share Posted February 15, 2006 Is he just planning on a 8.8 pumkin swap, pumkng and axles, or what? Are the axles beefier than a stock R200? Are they the same size/spline? An 8.8 sounds interesting I know they need braces because they have a weak cover but that's all i now about them. I'll have to do some research. I've been thinking about getting the R200 moustache bar and front diff mount for my 71 instead of cutting out the custom ones I have in my 72, if I don't repair the 72. Isk Quote Link to comment Share on other sites More sharing options...
Moridin Posted February 15, 2006 Share Posted February 15, 2006 Is he just planning on a 8.8 pumkin swap' date=' pumkng and axles, or what?Are the axles beefier than a stock R200? Are they the same size/spline? An 8.8 sounds interesting I know they need braces because they have a weak cover but that's all i now about them. I'll have to do some research. I've been thinking about getting the R200 moustache bar and front diff mount for my 71 instead of cutting out the custom ones I have in my 72, if I don't repair the 72. Isk[/quote'] I know the 03/04 Cobra axles should be far stronger than what comes with the R200 and maybe even the R230. Check out my thread on ideas for a 8.8" swap here: http://forums.hybridz.org/showthread.php?t=108135 Quote Link to comment Share on other sites More sharing options...
Cable Posted May 10, 2007 Share Posted May 10, 2007 Time to go to the top for some updates for the R230 mounts and the bolt-in 8.8 kit. Quote Link to comment Share on other sites More sharing options...
280Z28 Posted May 10, 2007 Share Posted May 10, 2007 Time to go to the top for some updates for the R230 mounts and the bolt-in 8.8 kit. I assume you want one or the other? I want the 8.8 kit... I wonder if he'd work a deal w/ some other susp. components. :hmm: Quote Link to comment Share on other sites More sharing options...
Cable Posted May 10, 2007 Share Posted May 10, 2007 I assume you want one or the other? I want the 8.8 kit... I wonder if he'd work a deal w/ some other susp. components. :hmm: At this point I am on the fence on which way I'll go. I'd rather have the CLSD in the 8.8 and the aftermarket gear set choices. On the other had I already have my R230 and one pair of halfshafts. So I just need to source one more pair and then buy the axles and adapters and I am set. I just didn't want to mess with drilling and modifying my stock mustache bar either. Quote Link to comment Share on other sites More sharing options...
