Beck Posted February 8, 2006 Share Posted February 8, 2006 OK everyone, we need to begin accumulating and compiling what we can here. I want only turbo info....ie VQ30DET. It would be a real disservice, if we began mixing this with the normally aspirated VQ30. There is so much different internally, that it is akin to saying z31 and z32 motors are the same because there are VG30s in both. So far about 98% of the information I have found is flat out wrong. If there is something you are not absolutely sure of, but would like to share, please flag it as 'might be' or 'possible'. Coming soon - I will have the wiring harness traced and labeled. Looky! No EGR - The boss in the manifold hasn't even been drilled out. Quote Link to comment Share on other sites More sharing options...
rp975 Posted February 9, 2006 Share Posted February 9, 2006 Hi, I am part way through putting a VQ30det neo into my 1974 260z, I don't know how to put the pctures up here but there are some pics in my gallery. Rob Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted February 9, 2006 Share Posted February 9, 2006 Wow rob nice fit, I thought it was a VG30det? We are talking about the same motor as seen here...http://classifieds.hybridz.org/showproduct.php?product=1895 Quote Link to comment Share on other sites More sharing options...
rp975 Posted February 9, 2006 Share Posted February 9, 2006 Hi Sparks280zt, Thanks, mine is a VQ30det neo from a HY34 99 model Cedric, it has an alloy block and a timing chain, single turbo. Rob Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted February 9, 2006 Share Posted February 9, 2006 ah i understand, thanks Quote Link to comment Share on other sites More sharing options...
triple B Posted February 9, 2006 Share Posted February 9, 2006 man you aussies get all the good engines. what is the VQ30det used in from nissan. far as i know we do not have it here in the states Quote Link to comment Share on other sites More sharing options...
rp975 Posted February 9, 2006 Share Posted February 9, 2006 Hi triple B, We do not have these motors in Oz normally, they are import only from Japan. I think that they came out in Hy33 and Hy34 nissan Cima and Cedric. I bought a front 1/2 cut of a 99 model Hy34 Cedric, mine might also have a CVT (constant variable transmission) style of auto, I won't know for sure untill I get it going. I also bought a worshop manual from Japan, and guess what ,it is in Japanese!!! der. It will be interesting when I get to the wiring stage. Rob Quote Link to comment Share on other sites More sharing options...
260DET Posted February 10, 2006 Share Posted February 10, 2006 I was looking at using a VQ30DET but it was so hard to find any reliable sounding info on their durability and reliability. Seeing 500whp is the aim this was an important consideration, gave up in the end and got a VG30DET instead. Quote Link to comment Share on other sites More sharing options...
Mack Posted February 10, 2006 Share Posted February 10, 2006 hey 260DET, look up HLH0501, he was a guy running a huge frigging turbo on a 5th gen maxima with a stock VQ30DE in it. he hit I think 500whp with something ungodly like 605wtq. granted he went through a few junkyard motors melting pistons, but he was still running stock electronics and didnt exactly tune it. If an NA block can make those numbers and just hole a piston, think of what a factory turbo block can make with proper tuning and something UNDER 10:1 compression. Quote Link to comment Share on other sites More sharing options...
260DET Posted February 10, 2006 Share Posted February 10, 2006 Yeh Mack, thats the sort of thing that came up, blokes getting good numbers but something always stuffing up on the VQ. Probably not due to any weakness in the VQ like you indicate but I know the VG will easily handle 500 at the wheels so...... Quote Link to comment Share on other sites More sharing options...
Beck Posted March 7, 2006 Author Share Posted March 7, 2006 Better late than never.... inside pix of the VQ30DET ecu I have. http://platrose.com/z/site/VQ30DET_ecu.htm Quote Link to comment Share on other sites More sharing options...
Beck Posted March 8, 2006 Author Share Posted March 8, 2006 I got a ton of pipes and hose with this motor, so I put this together to figure out which went where. Soon I'll get to pix of everything together. http://platrose.com/z/site/VQ30DET_induction.htm Quote Link to comment Share on other sites More sharing options...
