240Z_Master Posted February 28, 2006 Author Share Posted February 28, 2006 This is my other problem...(pix) Maybe the RB26 mechanical speed sensor out of the R32 can help me with this problem. Good thing about the electronic one is I don't have to worry about sticking a cable up in there. Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted February 28, 2006 Share Posted February 28, 2006 The sensor head on mine was only about 3-4mm. Those look way to deep to fit. You could cut off the stock mounting tabs and weld them back further down in the tunnel. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 28, 2006 Author Share Posted February 28, 2006 Ed260Z said: The sensor head on mine was only about 3-4mm. Those look way to deep to fit. You could cut off the stock mounting tabs and weld them back further down in the tunnel. Might be worth a shot to take though. Anyone else have any ideas? I might go to Autozone or something. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 28, 2006 Author Share Posted February 28, 2006 So I forgot my camera while I was at the shop again... and pulled out the mechanical speed sensor from the GTR (R32). The unit was exactly the same but the red gear on the GTR was shorter (and the teeth were pointed in the opposite direction! like ///) while the GTS red gear was longer and pointed like . My other concern now that I think about it, is the damn ECU, doesn't it require an electronic signal from the speed sensor (for the speed governor and crap). So it looks like I will end up ditching my mechanical speedo for an electronic one coming up very very soon! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 4, 2006 Share Posted March 4, 2006 240z master; I think I may have found a mech speedo drive in a pile of parts I saved when I took an old AWD rb26 box apart for the bellhousing. I saved all the goodies and just ran across them. I'm in Mobile Ala. right now, so when I get back home on Sun., I'll take a pic and see if you can use any of it.... Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 4, 2006 Author Share Posted March 4, 2006 Quote 240z master;I think I may have found a mech speedo drive in a pile of parts I saved when I took an old AWD rb26 box apart for the bellhousing. I saved all the goodies and just ran across them. I'm in Mobile Ala. right now' date=' so when I get back home on Sun., I'll take a pic and see if you can use any of it....[/quote'] Hey, thanks! QUESTION If the RB25DET is an electronic speedo sensor, doesn't that feed a signal to the ECU (For speed gov' and cruise control)? Like if I switched over to a cable style (RB26DETT), wouldnt that be bad since the ECU wouldn't be able to read a signal? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 5, 2006 Share Posted March 5, 2006 Quote Hey' date=' thanks! [b']QUESTION[/b] If the RB25DET is an electronic speedo sensor, doesn't that feed a signal to the ECU (For speed gov' and cruise control)? Like if I switched over to a cable style (RB26DETT), wouldnt that be bad since the ECU wouldn't be able to read a signal? Sorry... I can't help you on that one. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 5, 2006 Author Share Posted March 5, 2006 J. Soileau RB26zcar said: Sorry... I can't help you on that one. It's alright, I ordered the Z32 sensor and it should be coming soon! Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted March 6, 2006 Share Posted March 6, 2006 240Z_Master said: It's alright, I ordered the Z32 sensor and it should be coming soon! Let us know if it fits right. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 6, 2006 Author Share Posted March 6, 2006 Ed260Z said: Let us know if it fits right. Of course, but I don't tink you have to worry as much since you're running a 26 which runs off of a cable. Just make sure that you use the speedo pinion that came with your RB25DET trans onto your RB26 speed sensor. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted March 6, 2006 Share Posted March 6, 2006 I just skimmed over the thread and I don't kno wif this has been talked about but this might be of some use. I found a site that sells universal adjustable speedo sender. Don't know if it will work but worth looking into. I believe they have ones for fords also, heres the link http://www.prostreetonline.com/buy/programmable_electric_speedo_senders/5291/ Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 6, 2006 Author Share Posted March 6, 2006 mine off ebay was 43 shipped Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted March 6, 2006 Share Posted March 6, 2006 Quote Of course' date=' but I don't tink you have to worry as much since you're running a 26 which runs off of a cable. Just make sure that you use the speedo pinion that came with your RB25DET trans onto your RB26 speed sensor.[/quote'] I think that only the R32 had the Mech Speedo. All the pics that I've seen of the R33 & R34 tranny have an Elec Speedo Sensor. But I'll keep my fingers crossed. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 6, 2006 Author Share Posted March 6, 2006 Ed260Z said: I think that only the R32 had the Mech Speedo. All the pics that I've seen of the R33 & R34 tranny have an Elec Speedo Sensor. But I'll keep my fingers crossed. Yeah, now that I come to think of it, I've only looked at R32 GTR trannies. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 6, 2006 Author Share Posted March 6, 2006 GOOD NEWS! The Z32 TT sensor is the same! (I hope) The length is exactly the same too! It even has the groove for the circlip Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 6, 2006 Share Posted March 6, 2006 Thats great news... looks close enough to me. I'm going to pick one up myself, for a just in case 'r. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 6, 2006 Author Share Posted March 6, 2006 J. Soileau RB26zcar said: Thats great news... looks close enough to me. I'm going to pick one up myself, for a just in case 'r. Ebay was only $43 shipped compared to the $75 and up I found on kragen, etc.. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted March 7, 2006 Share Posted March 7, 2006 240Z_Master said: It's alright, I ordered the Z32 sensor and it should be coming soon! man i have two Z32 sensor sitting at home... I could send you one... Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted March 7, 2006 Author Share Posted March 7, 2006 ZXRockie said: man i have two Z32 sensor sitting at home... I could send you one... I don't know if you saw the picture above, but I already got it. THANKS THOUGH! Now if I can make it fit or work for that matter, I would be GOLD! Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted March 7, 2006 Share Posted March 7, 2006 240Z_Master said: I don't know if you saw the picture above, but I already got it. THANKS THOUGH! Now if I can make it fit or work for that matter, I would be GOLD! That's great man. All you have to do now is notch the brace going around the tranny tunnel. Quote Link to comment Share on other sites More sharing options...
