80LS1T Posted February 27, 2006 Share Posted February 27, 2006 Ok I posted in the fuel section but after 2 days of no replys and only 11 views, Im going to post it here hoping for some info... What I am looking for is opinions/experiece with tuning a/f ratios. I always though 12-12.5:1 was a pretty good tune. Does it matter if you are tuning for WOT or part throttle when trying to acheive these ratios or does it change when tuning from WOT to part throttle? Also does it matter if its a turbo/sc car vs a NA? Thanks, Guy Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted February 27, 2006 Share Posted February 27, 2006 I prefer to tune for 11.5-11.8 :1 on a high boost turbo car, n/a I believe you can get up around 14:1 and still be safe, hopefully the LS1 guys who have had their cars on a dyno can chime in to verify. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted February 27, 2006 Share Posted February 27, 2006 Optimal AFR's for your N/A LT-1 are between 12.8:1-13:1. I have done a lot of work at South Georgia Corvette and he has dyno tuned many LT-1 engines. I called them to verify those numbers. Good luck. Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 27, 2006 Share Posted February 27, 2006 Does it matter if you are tuning for WOT or part throttle when trying to acheive these ratios or does it change when tuning from WOT to part throttle? Thanks' date=' Guy[/quote'] Part throttle/cruise should be in the 14.7:1 range. If you have O2/ cloosed loop, it will try to keep it there. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted February 28, 2006 Author Share Posted February 28, 2006 Well thats pretty much what I was looking for. I was told by some SRT-4 guys that 12-12.5:1 is too lean and I thought they were crazy. I guess I can understand that for a turbo car you need some extra fuel incase of boost spikes(that my thinking anyways). I would feel pretty safe/happy with a tune for my LT1 in the 12's. Guy Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted March 4, 2006 Share Posted March 4, 2006 At part throttle/light load, Hondas, Toyotas and others will lean out to 17:1. Quote Link to comment Share on other sites More sharing options...
Clifton Posted March 4, 2006 Share Posted March 4, 2006 Some will but not all, the lean burn econo engines. Quote Link to comment Share on other sites More sharing options...
