rustrocket Posted March 2, 2006 Share Posted March 2, 2006 I found an ls1 for $2,000, includes everything`(harness, ecu, manifolds, etc) except the throttle body and accessories (dont care about those anyway...) with roughly 50,000 miles on it. the guy said the car was hit in the front and the radiator shorted out the battery. if i bring my own battery, should i be able to start the car? is $2k worth it for a reasonably low mileage engine? Quote Link to comment Share on other sites More sharing options...
rubin Posted March 2, 2006 Share Posted March 2, 2006 it may have shorted out the cpu as well... i guess you could try starting it and if it doesnt then bargain for a better deal Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted March 2, 2006 Share Posted March 2, 2006 make sure it cranks and even possibly fires... ive heard that if the LS1s get a tap on the crankshaft pulley it destroys the bottom end of the motor. its just a so so deal, Quote Link to comment Share on other sites More sharing options...
Lason Posted March 2, 2006 Share Posted March 2, 2006 I would say with no throttle body that thing isnt going to start. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 2, 2006 Share Posted March 2, 2006 For another $500 you can get a complete engine and tranny combo with a warranty http://cgi.ebay.com/ebaymotors/98-Trans-Am-Camaro-LS1-Engine-w-Auto-Transmission-97K_W0QQcmdZViewItemQQcategoryZ33615QQitemZ8043108237 Then again, you might be able to talk the guy down to less than $1500 Quote Link to comment Share on other sites More sharing options...
DaleMX Posted March 2, 2006 Share Posted March 2, 2006 It wont start without a TB, and if it did it would run lean. Not a good idea. And 2000 is the average price for a running LS1 but not a good price for that one. I'd go 1000 or 1500 max. If you decide to get it and want to turn it over then disconect the wiring harness from the coils (1 connector on each valve cover). Then see if it turns over ok. Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted March 3, 2006 Share Posted March 3, 2006 I just picked up a ls1 with 100 thou on it for 750 and bought a ecu for 165 and 6spd harness for 225....that was comp motor besides the oil pan. Food for thought... Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted March 3, 2006 Share Posted March 3, 2006 I've been told the 98 is the least desirable of the LS1's. There are differences from the 98 to 99-04. It's been a long day at work and I'm drawing a blank right now. I'm sure someone will chime in with them. JOEY Quote Link to comment Share on other sites More sharing options...
LS1 240Z Posted March 3, 2006 Share Posted March 3, 2006 97(vette only, 98 first year for Fbody)-99 dont have as good oil return or heads, in 00 they had updated the oil return and better heads (241 casting, but early 00 motors had the 8something heads) 01-04 had better rod bolts and LS6 intakes along with LS6 clutches. Quote Link to comment Share on other sites More sharing options...
rustrocket Posted March 3, 2006 Author Share Posted March 3, 2006 thanks for the info guys. i probably wont be buying this engine. apparently, good things come to those who wait. on a sidenote, the throttle body is still on the engine, but was going to be removed before the sale. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 3, 2006 Share Posted March 3, 2006 Stay away from it... The 97-98s are the worst.. The 97 out of the Vette and the 98 out of both the vette and the Fbody are known to be less than optimal motors. For $2000 you could have a nice stroker 402 Shortblock. Mike Quote Link to comment Share on other sites More sharing options...
BringIt Posted March 3, 2006 Share Posted March 3, 2006 Don't talk bad about my 98!! Quote Link to comment Share on other sites More sharing options...
