Peternell Posted April 10, 2006 Share Posted April 10, 2006 These cars are made less than 10 miles from my house. I may just have a reason to talk business with this company to find where the Port disctrict I work for can help in their growth. http://www.sscautos.com/ Record-breaking Times [Not yet established] but Aero ] which has 259 hp & 85 ft lbs LESS and weights 210 more than the Ultimate Aero SSC generated the follow 0 to 60 mph: 2.94 seconds 1/4 mile: 10.98 seconds at 138 mph Skidpad: 1.03 g 0 to 100 mph to 0: 11.66 60 mph to 0 (braking): 103 feet Specifications - Ultimate Aero Engine Type: Aluminium Block and Heads (V-8) Displacement: 387.2 cu.in. Bore x Stroke: 4.125 x 3.620" Compression Ratio: 8.975:1 Horsepower: 1046 bhp @ 6950 rpm Torque: 821 lb./ft. @ 6200 rpm Redline: 7200 rpm Fuel Injection: Electronic Sequential Port Weight: 422 lbs Oil: SAE 5W/30 Fully Synthetic Racing Induction System: Sequential, multi-port fuel injection. Supercharger with 14 psi boost pressure. Dual-forced air innercoolers. Fuel: 104 Pump Octane Chassis and Body Layout: Mid-Engine/Rear Drive Body/Frame: Carbon Fiber/Composite/Steel Space Frame Brakes: Front: 14.0" Vented Slotted Discs/6-Piston Calliper Rear: 14.0" Vented Slotted Discs/6-Piston Calliper Wheels: Forged 3-Piece Alloy 19x9" Front, 20x12.5" Rear Tires: Michelin Pilot Sport PS2 Front: 235 35 (YR)19 Rear: 335 30 (YR)20 Steering: Rack and Pinion, Assisted Turns, Lock to Lock: 3.5 Turning Circle: 41.6 ft. Suspension: Front: Unequal Length Upper and Lower A-Arms Coil-Over Springs/Adjustable Tube Shocks Cab Controlled Air Lift Anti-Roll Bar Rear: Unequal Length Upper Rocker and Lower A-Arm Horizontally Opposed Adjustable Coil-Over Springs Adjustable Tube Shocks Anti-Roll Bar The Dynamics of the Aero Coefficient of drag (Cd): 0.357 Frontal Area: 19.0 square feet Belly pan: Complete flat belly pan with rear Venturi tunnels. General Data Dry Weight: 2,640 lbs. Weight to Horsepower Ratio (lbs/hp): 2.52 New production record! Weight distribution F/R: Front: 42% Rear: 58% Wheel Base: 105.2" Length: 176.2" Width: 82.7" Height: 43.0" Ground Clearance: 3.5" Trunk Space: n/a Accommodations Seating Capacity: 2 Headroom: 38.5" Seat Width: 2 x 19" Leg Room: 47" Seat Bank Adjustment: 25 Degrees" Seat Travel: 6.0" Drivetrain Gear Ratio RPM MPH 1st 3.82:1 7200 44.65 2nd 2.15:1 7200 79.28 3rd 1.56:1 7200 109.27 4th 1.212:1 7200 140.63 5th 0.973:1 7200 175.19 6th 0.656:1 7200 259.75 Final Drive Ratio: 3.44:1 Engine RPM @ 60 Top Gear: 1550 Instrumentation Gauges: 260-mph Speedometer 8000-rpm Tachometer Oil Pressure Water Temperature Fuel Level Volt Audio/Video: Navigation System (optional) 10-Speaker Premium Audio/CD/DVD System (optional) 7.5" Video/DVD Screen (optional) Automatic Back-Up Camera (optional) Standard Equipment Includes: Power Windows Power Mirrors Tilt-Steering Cab-Controlled Front Air Lift Record-breaking Times [Not yet established] but Aero which has 259 hp & 85 ft lbs LESS and weights 210 more generated the follow 0 to 60 mph: 2.94 seconds 1/4 mile: 10.98 seconds at 138 mph Skidpad: 1.03 g 0 to 100 mph to 0: 11.66 60 mph to 0 (braking): 103 feet Quote Link to comment Share on other sites More sharing options...
tannji Posted April 10, 2006 Share Posted April 10, 2006 WOW! I love the car, and it sound sick.... pure sex. But.... over 700hp, 2800+ pounds, and it does a 10.98 in the 1/4? Something just doesnt seem right. I imagine I will be able to do that in my Z eventually, under 500hp, similar weight, and obviously a fraction of the cost. Perhaps they are geared for top speed, but still, 0 to 60 in 2.9 seconds, would expect a better 1/4... Quote Link to comment Share on other sites More sharing options...
280zex Posted April 10, 2006 Share Posted April 10, 2006 I was in the shop that makes the engine for this car. Unfortunatly I was not allowed to take any pix;-( I did get to sit in one though!! damn nice American super car!! Quote Link to comment Share on other sites More sharing options...
Guest l28et Posted April 10, 2006 Share Posted April 10, 2006 Seems like a capable performer but its not much to look at. Looks like a kit car. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted April 10, 2006 Share Posted April 10, 2006 i agree. Italy's still got us beat in looks. Quote Link to comment Share on other sites More sharing options...
vashonz Posted April 10, 2006 Share Posted April 10, 2006 I met one of the guys in charge of it at an auction in NYC last summer. He was pretty excited about them, and had lots of crazy stories about (street) racing lamborginis(sp). He said that when driving these he can walk away from bikes (I mentioned my R1) on the freeway. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted April 11, 2006 Share Posted April 11, 2006 Great looking car and love the concept. If that performance is real, then their HP claims are way off. A 0-60 of 2.94 means quick acceleration from rest but a 10.98 wih 138mph means the opposite. Of course, you do not take a car to the drag strip and make a couple of passes and expect to get max performance, so I give them some benefit of the doubt. The MPH shows it makes big HP but overall I would say the performance is about 150-170hp off their claim of 787. Great to hear from you again Larry. Hows the project coming? Quote Link to comment Share on other sites More sharing options...
Chewievette Posted April 11, 2006 Share Posted April 11, 2006 "Fuel: 104 Pump Octane" Did I miss something? I've Never seen this at any pump before ...at least not one for street use. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted April 12, 2006 Share Posted April 12, 2006 "Fuel: 104 Pump Octane" Did I miss something? I've Never seen this at any pump before ...at least not one for street use. They have it in Cali and in some pumps in AZ. I don't like the looks, but man, they said windtunnel testing top speed of 273 mph?!?!? Mario Quote Link to comment Share on other sites More sharing options...
olie05 Posted April 16, 2006 Share Posted April 16, 2006 I saw 105 at the racetrack near orlando. I even took a picture btw the headlights on that car look like they come off of another car, can't quite figure out which though. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted April 16, 2006 Share Posted April 16, 2006 btw the headlights on that car look like they come off of another car' date=' can't quite figure out which though.[/quote'] Yeah, I know what you mean, its going to drive me crazy now haha Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 16, 2006 Share Posted April 16, 2006 Thought it was a Honda Accord, but I was close. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 16, 2006 Share Posted April 16, 2006 ford focus headlights.. mike Quote Link to comment Share on other sites More sharing options...
olie05 Posted April 17, 2006 Share Posted April 17, 2006 rsx headlights? http://www.rsportscars.com/foto/02/rsxtypes05_11.jpg i don't know Quote Link to comment Share on other sites More sharing options...
