datsunan Posted April 11, 2006 Share Posted April 11, 2006 After finding problems with 2 of my injectors I took my cat to the dyno and finally got some more respectable #s. I still think there is more power to be found, I'm just not sure where to look. I think my AFR are good, changing my timing from 20 to 18 really helped my power above 5200 rpm. I don't know if I can take more timing out or if I should up the fp, or leave the fp and try more boost. I think it is running good enough that I could up the boost but with a felpro HG and stock head bolts that might not be such a good idea. What do you think? This was at 18psi. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted April 11, 2006 Share Posted April 11, 2006 Your A/F's could use a little adjustment. I'd lean it out to around 11.5-11.8:1 to keep it safe in the upper RPM's. You are losing power with the car running that rich. Also, see how power starts falling off after 5200? A good turbo cam may be in your future. That is where the stock turbo cam begins to run out of breath. Since you have the JWT setup, I don't know what tuning you can do... Good #'s though. 300rwhp is a handful in an S30 Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted April 11, 2006 Share Posted April 11, 2006 Nice. I would recommend and aftermarket programmable computer, I don't trust JWT to tune my ECU without my car. And then try adding more timing (EDIT: as in more advance), especially down low, before you lean it out. With a little fine-tuning, you can get a lot out of these motors. Ehhh, what motor are you running, by the way? For example, here's my VG30ET at 18 psi intercooled, t3/t04e (shameless self-tuning boast): Quote Link to comment Share on other sites More sharing options...
Thumper Posted April 11, 2006 Share Posted April 11, 2006 I think the rich top-end is hurting your hp alittle. I tuned mine to be high 11's at low-rpms and then mid 11's by redline. Also I ran 22psi on my stock block with stock head bolts but I did run a metal head gasket. Not sure on the felpro so your block could handle more. Also why would pulling timing make more power? Only way I could see that is if you were getting a miss. But usually more timing equals more power and more likely to detonate. Quote Link to comment Share on other sites More sharing options...
datsunan Posted April 11, 2006 Author Share Posted April 11, 2006 I don't know why when I pulled timing it had a significant improvement on the curve above 5200. At 20 it dropped off alot after 5200 and at 18 it stayed flat till over 6000. I'm surprised it so rich since last time I dynoed it was much leaner and I only made 275 hp Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted April 26, 2006 Share Posted April 26, 2006 looking at your Sig... You made 305 rwhp on a t3/t4? Is that the stock ZX turbine? Also what are the AR's for bothe hot and cold side (just curious). If so... Excellent!!! Quote Link to comment Share on other sites More sharing options...
datsunan Posted April 26, 2006 Author Share Posted April 26, 2006 The housing is stock but I believe the turbine is upgraded. Check out Jim Wolf technologies if you want to know the specifics. I bought it 4 years ago and did not care back then what the AR's were, now I'm kinda curious. Quote Link to comment Share on other sites More sharing options...
Guest Jason84NA-T Posted April 27, 2006 Share Posted April 27, 2006 Nice numbes, those torque figues look quite good... That thing must move nicely! Sorry if I take a tangent here..... The JWT tune is very rich, but yours is running a tad rich even for their default tune. I can see ~20hp to be gained right there, and probably another 10-15 by revising the timing maps. There is a lot of potiential on the system you have it it is tuned WELL and not just a default JWT. You can do all of this with the setup you have plus a romulator and a laptop. Or you can always have someone bun you a new chip with just the AF corected a little. Info on me site hee if you ae inteested: http://www.redz31.com/pages/fuel/romulator.html These are the gains at the same boost pressure (edit: which was 15.8psi) that I realized by re-tuning the JWT progam on a Z31: That's what I gained with 2 hous on a dyno simply by making new fuel and timing maps. Sure, the JWT tune is not bad... but it's far too conservative and geneic to be taken seriously for anyone wanting to make the most of what they have. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted May 2, 2006 Share Posted May 2, 2006 Also why would pulling timing make more power? 90% of the time advancing the timing will increase power. However, advancing timing as close to detonation is not always the best idea for power. Some motors like to have more retarded timing in some areas versus others. Only dyno time, preferably with a knock sensor, can tell. IE, 40 degrees gives me detonation, 39.9 is where I have it--but in all actuality, 36 is where it likes to be for power. Quote Link to comment Share on other sites More sharing options...
