nazar Posted April 28, 2006 Share Posted April 28, 2006 Well Ive had my azc brake kit on for a while, and i like them I also installed the 280zx master. Everything has been fine but recently i broke a leak inside the cab where the brake pedal is, everytime i push on it i can hear vacuum leak or whatever you wanna call it and the revs go up if i do this at idle(lt1 engine) So is my booster done? Or is there another part between the booster and pedal? Do i rebuild the booster or just buy a new reman. one?? This sux, its like having manual brakes again, lol Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted April 28, 2006 Share Posted April 28, 2006 I could be wrong but sounds like a booster problem. I had the same problem with a previous z and ended up getting a new booster. Henry Quote Link to comment Share on other sites More sharing options...
Alf Posted April 28, 2006 Share Posted April 28, 2006 It may just be the check valve. If the booster is leaking air that means your engine has a vacuum leak, is it running differently? Try disconecting the hose and putting a cap on the carb port and see how it runs, if its the same its probably not the booster. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 28, 2006 Share Posted April 28, 2006 When my friend's booster went bad in his Supra it sounded like a whistle under the dash. A couple days later it was like a duck was living under there. What's probably going on is the diaphragm inside the booster has a tear and you're hearing the air pass through. Sounds like it's time for a new booster. Quote Link to comment Share on other sites More sharing options...
nazar Posted April 28, 2006 Author Share Posted April 28, 2006 yeah the idle goes up when i push the pedal and it leaks air damn...that sux, where do you find a new booster, lol Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 28, 2006 Share Posted April 28, 2006 What year? I think I have my early 240 booster in the classifieds... Quote Link to comment Share on other sites More sharing options...
nazar Posted April 28, 2006 Author Share Posted April 28, 2006 71 240z can you rebuild them? New ones are like $100 Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 29, 2006 Share Posted April 29, 2006 I don't know if you can rebuild them or not. I seem to recall new ones being more like $250, but I just check and black dragon has them for $150. I guess that means I'm asking too much in my classified. Oops. If you want to make an offer... Quote Link to comment Share on other sites More sharing options...
2126 Posted May 1, 2006 Share Posted May 1, 2006 The master-vac is rebuildable however, it can become a safety issue trying to disassemble the unit without the correct tool and a good solid bench mounted vise. Basically, there is a big strong spring that lives inside with the diaphram so be fore warned. Kits are available and cost less than a new unit. Quote Link to comment Share on other sites More sharing options...
