Can I safely cut this out of my door?
I'm gutting the doors and I'd like to cut along this red line and plan on using lexan windows. Would the door remain structurally sound? I believe there is a door bar in it, if I were to remove that as well, would it still be rigid enough then? I just dont want the door to flex and wobble enough to come loose from the door latch.
also, assuming all is well to go ahead and cut, would you guys recommend using a Sawzall or an angle grinder with a cutoff wheel? thanks in advance! hope to tackle this by the weekend.
  Quote
I'm gutting the doors and I'd like to cut along this red line and plan on using lexan windows. Would the door remain structurally sound? I believe there is a door bar in it' date=' if I were to remove that as well, would it still be rigid enough then? I just dont want the door to flex and wobble enough to come loose from the door latch.
[img']http://i1.tinypic.com/xmtk6b.gif[/img]
You can see that there is a boss (for lack of a better word) about 2" in all the way around the door. (some of your line is on it)
I would only remove the inner part leaving the boss all around the door for strength.
I would also leave the door bar in place.
Get a short sawzall blade and take your time cutting.
Find some small "c" channeled molding to trim it out when you done so you wont get cut by the sharp edges left on the door.
Don’t know if it will pass a vehicle inspection in your state, you might want to check before you cut.
Is this a race car? If so I would cut the brace out too if there are door bars. I have fiberglass doors on my 71 that are cut out the way you have lined. They have some flex, I'm sure alot more than a gutted steel door and are fine. I don't run windows though.
well, assuming i have the funds, the car will primarily be sorted for the track, but i hope to take it out on the street every now and then as well.
here are some updates:
the tools i used
the sheetmetal i cut
the final product
the leftovers (its for sale if anyone is interested)
now the door shuts nice and firm with a solid thunk!
as long as you use keep the edge profile height (thickness) of the door intact.. you will have a sturdy door.. some of the early 240Z doors had no side impact bar... you can remove the bar without causing any problems... except less crash protection...
