Nathaust Posted May 12, 2006 Share Posted May 12, 2006 Where do all of you get your 3 inch mandrel bent exhausts made for your L28ET? I went to a coulple muffler shops in the area and they said they didnt even know where I could go to get a mandrel bent system made up. I knew crushed type benders were more popular but I didnt think it would be to difficult to find someone to make it. Do any of you Washington residents know where I could go? thx john Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 13, 2006 Share Posted May 13, 2006 Buy the bends from Summit or Jegs or JC Whitney, then take them to an exhaust shop. If you're looking to save $$$, buy your muffler through mail order too. I paid $17 for my Dynomax UltraFlo through Jegs when they were on sale (mail in rebate, but it was worth it for $50!). I think the local muffler shop will probably want $100 for the same muffler. Quote Link to comment Share on other sites More sharing options...
Nathaust Posted May 13, 2006 Author Share Posted May 13, 2006 Thx Jon that sounds like a good way to go about it. Did you do it with all 90 bends or did you use any 45 ect.. Quote Link to comment Share on other sites More sharing options...
spork Posted May 13, 2006 Share Posted May 13, 2006 I bought 180 degree u bends and then cut them up as needed Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted May 13, 2006 Share Posted May 13, 2006 Stans headers down in Auburn will do mandrel bending, I doubt its cheap though... http://www.stans-headers.com/ Actually, im kinda curious about the price, Im going to need a 3" system done for my Z hopefully later on this summer.... maybe they will do a group rate Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 13, 2006 Share Posted May 13, 2006 I bought 180 degree u bends and then cut them up as needed That's what I did too. Cheaper than to buy one 180 than 2 90s. Quote Link to comment Share on other sites More sharing options...
Andrew Bayley Posted May 15, 2006 Share Posted May 15, 2006 Remember one thing though... most mandrel bends aren't 100% perfect. There is still going to be some deformation of the diameter inside the bend. You will need to weld the difference at the pipe connections if you cut inside the bend and splice a pipe into the cut. Quote Link to comment Share on other sites More sharing options...
seth Posted May 15, 2006 Share Posted May 15, 2006 I bought 180 degree u bends and then cut them up as needed Me too... and in my intercooler piping... when the bend got too tight i just cut wedges out of straight pipe and welded it togeather... Quote Link to comment Share on other sites More sharing options...
aarang Posted May 15, 2006 Share Posted May 15, 2006 I've gotten a few systems done at Stans Headers. I don't think it will cost you more than $300 for aluminized steel. It's been a while, but one guy there does crappy work ( Stan's brother) and another younger guy there did really nice work. Aaron Quote Link to comment Share on other sites More sharing options...
johnc Posted May 15, 2006 Share Posted May 15, 2006 One thing that's nice about dealing with Burns Stainless or SPD is that you can get things like a 3" U bend on a 3" center-line-radius. They are more expensive then Summit but the bends are a constant 3" OD and can be super tight. You can also order .49" thick mild steel bends. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted May 16, 2006 Share Posted May 16, 2006 You can also order .49" thick mild steel bends. What the heck would you use that for? Quote Link to comment Share on other sites More sharing options...
Z-TARD Posted May 16, 2006 Share Posted May 16, 2006 What the heck would you use that for? Coolant piping for the reactor..... Quote Link to comment Share on other sites More sharing options...
Z-TARD Posted May 16, 2006 Share Posted May 16, 2006 These guys have bends and pipe for reasonable prices: http://stores.ebay.com/Verocious-Motorsports_Bends_W0QQcolZ2QQdirZQ2d1QQfsubZ3QQftidZ2QQtZkm Quote Link to comment Share on other sites More sharing options...
johnc Posted May 16, 2006 Share Posted May 16, 2006 Sorry, missing zero. .049"... 'Course, if there is a minimum weight for the class and your car is WAY under it, what better place to put weight. Quote Link to comment Share on other sites More sharing options...
boardkid280z Posted May 24, 2006 Share Posted May 24, 2006 Another place I found that sells them for a decent price is these guys: http://store.racing-solutions.org/index.html Great service and fast shipping. I got the 3" exhaust builder kit - comes in aluminized steel. I used a 180 and one 45 degree bend for the downpipe, so i still have another 180, two 90's and a 45 to finish the rest of the exhaust. Bought the O2 bung from them two. Quote Link to comment Share on other sites More sharing options...
Nathaust Posted May 28, 2006 Author Share Posted May 28, 2006 Cool, thanks for all the replys. I'll give the stans place a call first to see what kind of prices they have. I was planning to just buy some generic U and 90 bends from summit but I'll check out those other sites. I have a down pipe so I don't think it would be to difficult to fab the rest of the plumbing. I've been looking at what others have done and it looks like the best I've seen go from the DP shifting over towards the driveline and stright down and then 45s over to the muffler. I've seen a lot of people use 90 in the rear to get from the center of the car over to the muffler. I've only seen one picture using 45's why is that? Is it a clearance issue? wouldnt 45's be better for flow? What should I look for in a muffler. I was looking at just some high flow straight through types but there is a lot of variations. Will just any 3in in/out straight through work. I'm assuming the longer ones are quieter then the shortys. I was looking at the Borla ones in the summit cat. but I'm not really sure what would be best. thx john Quote Link to comment Share on other sites More sharing options...
rdelat Posted August 7, 2006 Share Posted August 7, 2006 ubendman on ebay www.rjcustompiping.com i make and sell bends fab exhaust Quote Link to comment Share on other sites More sharing options...
280Z28 Posted August 7, 2006 Share Posted August 7, 2006 After you put your system together, I recommend sending it here to protect it: http://www.thermaltechcoatings.com Quote Link to comment Share on other sites More sharing options...
