Ray Posted February 23, 2001 Share Posted February 23, 2001 I have seen 245's any body tried 255's and what with of rim did you use???? Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 24, 2001 Share Posted February 24, 2001 I think I'm going to go with 245s myself, I HAD been considering 255s. The reason? Nitto just now released a new drag radial in a 245 45R17 size I intend to do this with an 8 inch rim and if I goto 255 for some reason that's the same rim I'd use. A 9inch would be a problem to fit in my wheelwells and I already know that 245's fit just fine on an 8inch rim. Actually - that rim might even be 7 or 7.5 - I've never measured (stock Mustang rim from 94-95 in 17inch). I'll research that and try to get back - I can't imagine an extra 10mm needing too much more rim so 8inch ought to be fine IMO. Oh, and no I've not test fitted either width - I believe 245 to be safe as you've stated. MikeKelly has flares but not up front so I'll be interested in his results and perhaps he can estimate the rear for us? [This message has been edited by BLKMGK (edited February 23, 2001).] Quote Link to comment Share on other sites More sharing options...
Ray Posted February 24, 2001 Author Share Posted February 24, 2001 I should have stated in the rear of the car.. I already have 225/50's in front... I was wondering if anyone has tried them with a 8" wheel in the back.... Quote Link to comment Share on other sites More sharing options...
pparaska Posted February 24, 2001 Share Posted February 24, 2001 Check out: http://24.4.88.29/ubb/Forum6/HTML/000408.html There's a discussion of wheel/tire sizes there. I doubt the 255/50-16 will fit easily, as a coilover, fender lip rolling, and a short spring is needed to JUST GET a 255/45-17 under a stock wheel well (see my site for details.) I'd think that with the strut being farther out 1/2" below compared to where the 17x9 and 255/45-17 come close to it, you'd need that much less backspacing, pushing the tire out too far for a stock fender. Maybe a fender trim or slight pulling out would make it work. ------------------ Pete Paraska - 73 540Z - Marathon Z Project pparaska@home.com Pete's V8 Datsun 240Z Pages [This message has been edited by pparaska (edited February 23, 2001).] Quote Link to comment Share on other sites More sharing options...
Ray Posted March 1, 2001 Author Share Posted March 1, 2001 thanks pete, I am going to try and get a set of used ones just to give it a try before I buy a some... Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 1, 2001 Share Posted March 1, 2001 I don't think you could squeeze them in on the rear... I think you would have to have about 5 inches of backspacing. That would require coilovers and MIKE/SCCAs collar perch idea. Even then, I doubt if the tires would fit inside the wheel well... Not much room without opening up the fender. Mike ------------------ http://hometown.aol.com/dat74z/myhomepage/auto.html "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted March 12, 2001 Share Posted March 12, 2001 Anybody, Can someone please tell me positively if a P245/45R17 tire can fit within the wheel wells of the Z - front and back. From what I can tell a p245/45 is approx. 9.8" wide. Also, does the hub (tire mounting surface) sit dead center within the well or is it offset either to the fender or towards the center of the car. I have some rims in mind that are 8" wide with a 4.5" backspace (I think this is 0 offset) but trying to determine if they will fit front and back. Thank You, Danno74Z Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted March 12, 2001 Share Posted March 12, 2001 Dan & Owen, Thank you for the help on the rims. Dan, I am looking at what you said closely because you are now using the tire size I want to use except my future rim is 17" vs your 15" rim. Did you use the same tire and rim up front? This is very important! Also, on your coilovers (I too will be using them) did you use camber plates or stay with the OEM top rubber perch setup. Thanks guys for the input as I now have a source for rims and any backspacing I need from 3.5" to 6.58". So, if I can nail down the backspacing I'm on my way on ordering rims. I'm spending a little more for the rims but I know with some good measuring they will fit in the wells. Danno74Z Quote Link to comment Share on other sites More sharing options...
Owen Posted March 13, 2001 Share Posted March 13, 2001 I think you're gonna need the coilovers. Mine are 245/55/16 10" wheel width. Don't know what the offset is. http://www.homestead.com/s30z/files/smyz080800-05.jpg They don't stick out that far but of course I have the coilovers. I will use flares though. Owen ------------------ http://www.homestead.com/s30z/index.html [This message has been edited by Owen (edited March 12, 2001).] Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted March 13, 2001 Share Posted March 13, 2001 I have 245/50/15 Dunlop SP8000s mounted on Centerline 15x8 inch rims with a 5 inch backspacing. I am running the coil-overs. The tires barely fit within the stock rear wheelwells. I have less than 1/8" clearance on the inside between the weld-on spring perch and tire. If the spring perch was relocated above the tire (8 inch 350 lb/in springs) ,and wheels with 5.5 inches of backspacing were used then maybe the 255 might fit. Good Luck, Dan Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted March 13, 2001 Share Posted March 13, 2001 I am using the same rims front and back 15x8 w/5 in backspacing. I have 245/50/15 on back and 225/50/15 on front. I have coil-overs on all four corners. (10 in 200# on back and 12 in 175# on front. The 245/50/15 will fit on the front( I wasn't sure when I ordered tires so I got 225s). I still have OEM rubber isolators above springs. This is not a problem on back but on the front I only have ~2 inches of shhock travel. I plan to get camber plates for the front. What it boils to is get 1? x 8 rims with a 5 to 5.5 in backspacing. Quote Link to comment Share on other sites More sharing options...
madmanadam Posted March 13, 2001 Share Posted March 13, 2001 Just found this site. http://www.rsracing.com/tech-wheel.html ------------------ Fun in the sun in shacky Washington 1972 240 V8 Topless for ever. zya8ter http://www.madmanadam.com Quote Link to comment Share on other sites More sharing options...
