Guest 280ss1976 Posted July 10, 2006 Share Posted July 10, 2006 i snapped my half shafts last thursday and have replaced them amnd alll universal joint but when i tap the gas i still here a tink noise that sound like bad u joints what would be some thing to look for Quote Link to comment Share on other sites More sharing options...
buZy Posted July 10, 2006 Share Posted July 10, 2006 Front pinon or m-bar mount maybe. Make sure to check the diff mounting locations for movement. In gerenal the front pinion raises up under load and that maybe the noise you hear. Quote Link to comment Share on other sites More sharing options...
Mike C Posted July 10, 2006 Share Posted July 10, 2006 Damaged spider gear cross shaft and/or damaged spider gears as well. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted July 10, 2006 Share Posted July 10, 2006 Sorry to hear about your half shafts / rear end. We have I think 3 spare R200 rear ends if you are interested in one of them. Let me know and I can ask my brother, since you live in S.C. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted July 10, 2006 Share Posted July 10, 2006 could be where the bolts from the diff go through the moustache bar. If the nuts on them losen up it sounds like a bad U-joint. Quote Link to comment Share on other sites More sharing options...
Forrest Posted July 10, 2006 Share Posted July 10, 2006 Make sure your driveshaft bolts and the halfshaft bolts you just put on are still tight. Check the mustache bar nuts, your diff mount, and look at the strap on top of the diff and make sure it's in the right spot. Hopefully it's something small. Quote Link to comment Share on other sites More sharing options...
Guest 280ss1976 Posted July 11, 2006 Share Posted July 11, 2006 it turned out to be the u joint on the main drive shaft number 2 ujoint the connects to the rear end i cracked the one also i guess when i changed it i torqued up again and i guess it cracked so i upgraded to brute u joints lets see how they hold up but the ride is alot smoother thank god it not the rear end but i puttin a ford 9 in it soon so if u know any thing to help let me knowthanks for ya help Quote Link to comment Share on other sites More sharing options...
