108,920 Hp
skipzoomie
Impressive, but nuclear marine powerplants are considerably more powerful. And gas turbines, while nowhere near as torquey, have much higher power density, and could probably be combined to spin the same propeller. Of course, there's much to be said for the efficiency and durability of an inline-Diesel.
the power density of that thing is pretty bad, but the torque per lb is right on. If they could get that thing into the 4-5k RPM range maybe we'd be talking some reasonable ratings. for a 4,600,000lb engine only producing 108,920 hp, that's awfully wasteful. If you stacked SBC's you could build maybe 100-200 of them to equal the HP, but the weight would only be maybe 90,000 That's quite a weight savings! Add a few tonnes for gearing and you got yourself the same thing, no doubt less reliable but still. And those end cap bolts don't look nearly big enough IMO. Let's hook it up to the dyno and *proove* it's even getting that much torque.
You may be right, but still, if you added a couple of turbos..........:)
