jbk240z Posted August 6, 2006 Share Posted August 6, 2006 check it out on ebay, item #260017208028. It looks like a decent part. Although I don't now how well it would work on a daily driver. Quote Link to comment Share on other sites More sharing options...
buZy Posted August 6, 2006 Share Posted August 6, 2006 It would be just fine, You wouldn't notice a difference if any. Arizona Z car sells the same part for less money than that Ebay auction. AZC parts are the of best quality and performance bar none. Check it out and see for yourself. Brian http://www.arizonazcar.com/diffmount.html Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 7, 2006 Share Posted August 7, 2006 You might want to read around. Search on solid diff mount. Experiences with solid diff mounts vary. On my 240 it was so loud I got physically ill after 10 minutes of driving. Other people had a less severe noise problem. Quote Link to comment Share on other sites More sharing options...
Clifton Posted August 7, 2006 Share Posted August 7, 2006 I could only take mine for about 10 minutes also. They do add quite a bit more noise that I couldn't live with for a street car. Quote Link to comment Share on other sites More sharing options...
smoorenc Posted August 15, 2006 Share Posted August 15, 2006 Ditto for me. I ended up taking it off 1 week later. I even tried sliding a piece of radiator hose in between. Quote Link to comment Share on other sites More sharing options...
RedNeckZ Posted August 18, 2006 Share Posted August 18, 2006 I have one on my daily driver and like it a lot better then the old mount. But I am also not very stock any more. Just stripped the insides out and installed a rollbar. So noise is not a problem with me. It did stop the rearend hitting the tunnel everytime I dropped the clutch. Maybe you should try the system of wrapping a cable around the front mount to hold it in place. It seems to work for most people. Check this area with a search try and see what comes up. It has been talked about. The people at Jags that run, makes a book about info on how to do a V8 conversion for the Z. It also talks about some great info on the cable idea. Good Luck, Rich. Quote Link to comment Share on other sites More sharing options...
