Wierd ZX Option
Warren
I yoinked one of those switches from the junkyard, hoping to adapt it to my 280ZX, but I haven't had time to investigate that yet. Like, if simply wiring up the switch in place of a regular switch will make it work, or if there's other components that's needed.
There is also a module that does the Auto function, and I think that the P/W motor is different, but I am working from memory. I will check and let you know.
You can buy window close modules that can be adapted, they are commonly used with alarm systems to close all your windows when you remote lock/arm your alarm.
