evans280z Posted October 2, 2006 Share Posted October 2, 2006 whats the big peice of L-shape metal that goes under the rearend on a 78? do i really need it. Quote Link to comment Share on other sites More sharing options...
280Zone Posted October 2, 2006 Share Posted October 2, 2006 Designed to reduce vibration. It seems it was an afterthought though. Quote Link to comment Share on other sites More sharing options...
evans280z Posted October 2, 2006 Author Share Posted October 2, 2006 can i do without it Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 2, 2006 Share Posted October 2, 2006 Designed to reduce vibration. It seems it was an afterthought though. No. There were weights that were dealer installed on the rear diff of the early 240Zs to reduce vibrations, but they had it figured out that by moving/repositioning the differential, the half shaft angles would be correct and this would eliminate the vibrations. The later 240Z, 260Z, and 280Z cars never had such an issue. Please post a picture of what you are talking about. Davy Quote Link to comment Share on other sites More sharing options...
evans280z Posted October 2, 2006 Author Share Posted October 2, 2006 dont have a camera. fits on the bottom of rearend two (14 bolts) hold it up Quote Link to comment Share on other sites More sharing options...
crazy canuck Z8 Posted October 2, 2006 Share Posted October 2, 2006 My r200 has that plate with 5 small pieces welded on ,i was going to leave it off but thought i had better not mess with a good combo. Quote Link to comment Share on other sites More sharing options...
280Zone Posted October 2, 2006 Share Posted October 2, 2006 I have had them on all of my 280's, maybe we are talking about something else. Quote Link to comment Share on other sites More sharing options...
TimZ Posted October 3, 2006 Share Posted October 3, 2006 No. There were weights that were dealer installed on the rear diff of the early 240Zs to reduce vibrations, but they had it figured out that by moving/repositioning the differential, the half shaft angles would be correct and this would eliminate the vibrations. The later 240Z, 260Z, and 280Z cars never had such an issue. Please post a picture of what you are talking about. Davy No, there was still a mass damper installed on my '78. It was bone stock when I bought it in 1980 (yes I've had my car that long ). Most likely for curing some NVH issue - probably some resonance caused by gear whine. Mine fell off years ago (circa 1981), and I've never been able to tell the difference. So, to answer the original question, I'd say no you don't need it. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 3, 2006 Share Posted October 3, 2006 My 70 didn't have this thing, FWIW. I've seen it in pictures and always thought "Well THAT would be the first thing to go in the trash can." Quote Link to comment Share on other sites More sharing options...
veritech-z Posted October 3, 2006 Share Posted October 3, 2006 I swapped my diff to an R200 on my 77, and ended up with that thing as an extra part...I had no idea where to put it, and no memory of where it came from, but it sure does make a good doorstop... Quote Link to comment Share on other sites More sharing options...
evans280z Posted October 3, 2006 Author Share Posted October 3, 2006 about how much do it weigh Quote Link to comment Share on other sites More sharing options...
veritech-z Posted October 4, 2006 Share Posted October 4, 2006 I'd say several pounds, but I haven't got any hard numbers to offer you. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 4, 2006 Share Posted October 4, 2006 The one I removed from a 76 2+2 parts car weighs close to 10 lbs.... Quote Link to comment Share on other sites More sharing options...
Cruez Posted October 4, 2006 Share Posted October 4, 2006 I yanked mine years ago on my '77 and '78... Never noticed any difference. Quote Link to comment Share on other sites More sharing options...
