Andrew Bayley Posted March 8, 2001 Share Posted March 8, 2001 ...what is the firing order on a Small Block Chevrolet. Also, I need someone to refresh my memory on how the cylinders are numbered. It's been a long time since I've had to do this, so cut me some slack, Jack. Also, I've been wrapped up in Dad's "Blown Big Block" project that I've forgetten most of the small block basics. After working on (or shall I say "in") the boat, my V8 looks tiny. -Andy Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted March 8, 2001 Share Posted March 8, 2001 Correct me guys if I'm wrong but I believe that all of GM's current (1955-to now) V8 Over head Valves V8's have had a firing order of: 1,8,4,3,6,5,7,2. That's just from memory but I believe that is correct. The cyl's on the driver's side are the odd #'; 1,3,5,7 while the passenger's side are the even #'s: 2,4,6,8. I believe that is what you were looking for. Kevin, (Yes,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 8, 2001 Share Posted March 8, 2001 Andy, I believe Kevin is correct on everything except (And I might be wrong as well..puliing from memory) The firing order... instead of 4-3 it should be 3-4, no? Mike ------------------ http://hometown.aol.com/dat74z/myhomepage/auto.html "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
pparaska Posted March 8, 2001 Share Posted March 8, 2001 Even though Kevin's still an inliner, he got all of that correct. The cylinder numbering starts at the front of the block. You'll notice that the left bank of the engne (driver's side for us left hand drive people) had the head slightly ahead of the other bank. The cylinder numbers are from front most to rear most. The driver's side cylinders 1,3,5,7 just a rod's width ahead of the respective passenger side cylinders 2,4,6,8. Firing order 1-8-4-3-6-5-7-2 I'd have to pull the cap and crank the engine to be sure, but I believe the distributor runs clockwise, looking down on the rotor. ------------------ Pete Paraska - 73 540Z - Marathon Z Project pparaska@home.com Pete's V8 Datsun 240Z Pages Quote Link to comment Share on other sites More sharing options...
Oltmann Posted March 8, 2001 Share Posted March 8, 2001 quote: Originally posted by Kevin Shasteen: Correct me guys if I'm wrong but I believe that all of GM's current (1955-to now) V8 Over head Valves V8's have had a firing order of: 1,8,4,3,6,5,7,2. That's just from memory but I believe that is correct. The cyl's on the driver's side are the odd #'; 1,3,5,7 while the passenger's side are the even #'s: 2,4,6,8. I believe that is what you were looking for. Kevin, (Yes,Still an Inliner) Kevin, You are correct about the firing order. One small block has a different order though, the LS1 which is 1-8-7-2-6-5-4-3. Quote Link to comment Share on other sites More sharing options...
Guest RON JONES Posted March 8, 2001 Share Posted March 8, 2001 Big Blocks share the same firing order as well. Quote Link to comment Share on other sites More sharing options...
Andrew Bayley Posted March 8, 2001 Author Share Posted March 8, 2001 Thanks guys. For some reason unknown to myself, every time I work on two motors side by side (in a boat) my sense of cylinder numbers gets all screwed up. Oh well. If any of you guys are ever in my neck of the woods and want to go for a boat ride, look me up. Of course, you will need to do it within the two weeks of boating we have up here -Andy Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted March 8, 2001 Share Posted March 8, 2001 Now that would be fun; The Boat Races on the Great Lakes in Michigan! More fun than one person should be aloud to have. Hey; if I show up do you think the rooster tail of one of those speed boats would knock me down if I wanted to go skiing behind it? Kevin (Yes,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 9, 2001 Share Posted March 9, 2001 Pete's right about the rotation of the rotor in the distributor too. Good luck! Larry Quote Link to comment Share on other sites More sharing options...
John C Posted March 9, 2001 Share Posted March 9, 2001 Brain fade........ it'll get you in these long winter months . John C Quote Link to comment Share on other sites More sharing options...
Andrew Bayley Posted March 9, 2001 Author Share Posted March 9, 2001 Ha ha ha, Laugh all you want Kevin, but I've actually skied behind the old man's 32 foot Offshore before. We took two (yes, two!) 75 foot ski ropes tied together and used that for a rope. It took forever to get up, but once I did... hang on. I was only going about 40 mph so the spray off the boat wasn't that bad. The rooster tail doesn't really come on until about 70 mph with the drives trimmed all the way out. Also, if you show up within the next three months, bring a dry suit and a U.S. Coast Guard Ice Breaker ...now thats what I'd call "Brain Freeze". -Andy Quote Link to comment Share on other sites More sharing options...
