woodboxer Posted January 26, 2007 Share Posted January 26, 2007 OK heres what I'm talking about. On the rear I would have to install a sheet across the entire rear as it is not an even plane , i am going to install a piece of 3" channel then cover the entire end from the spot where it goes in and wrap it under , plus I have to do something with the sides where there is an 1/2 " comes out and while doind this try to wrap the piece around the sides and make it look OK so as you can see there is a large indent that has to be filled in, Quote Link to comment Share on other sites More sharing options...
woodboxer Posted January 26, 2007 Share Posted January 26, 2007 here is another pic sorry i can't get it bigger , I copied it from paint and can't seem to enlarge it , i wanted to show where I want to do repair , so I added that info in paint but now I have to fiquire out how to enlarge it, any suggestions? sorry about that bob Quote Link to comment Share on other sites More sharing options...
RedFive Posted January 26, 2007 Share Posted January 26, 2007 Oh, I see what you're talking about now. Never knew what a ZX looked like back there. Good flippin luck. That looks like hell. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted January 26, 2007 Share Posted January 26, 2007 Woodboxer, On the ZXs it's not the back that you should worry about. You can put sheet metal bridging from the bottom of the tail lights down to the lower valence. I remember when I did mine I had to smash the lower valence in to get a nice contour. The biggest problem is making the sides look presentable. Check my web site for my Yellow ZXT for more pictures. GL Vinh Quote Link to comment Share on other sites More sharing options...
woodboxer Posted January 26, 2007 Share Posted January 26, 2007 hi Vinh, i have seen your car before and actually thats were I got the idea from, so how did you do the sides , I don't think the rear is a problem but the sides may be a different story, do you have any pics that show what you did? btw I really like what you did with your 81 zx , it shows you can do anything if you put your mind to it, did you put anything under the rolled sheet at the rear in case of an accident? I am planning on putting a steel channel there as there is enough room. So if I cut the spot where it goes out then bend it in and reweld it , that should do it.??? btw how did you do the rear skirt behind the tire? SO many questions , so little time,,,LOL. thanks for the responses ....bob Quote Link to comment Share on other sites More sharing options...
subridersix Posted January 27, 2007 Share Posted January 27, 2007 I'm a little concerned about making a void by cutting a filler piece of metal and welding it flush over a indentation. There's really no way to avoid having exposed metal behind your patch even if it's only the small amount caused by the welding. Add condensation and time and I think you'd have a pocket of rust. I would cut out the area, butt weld in your patch and then carefully preserve the back side. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted January 27, 2007 Share Posted January 27, 2007 GOTHALOSISM said: depends on the state you live in hmm...does anybody know what the law is about back bumpers in Ky? Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted January 28, 2007 Share Posted January 28, 2007 Woodboxer, Sorry I didn't take any picture while I was doing the rear on my 81. That was my first Z that I made a lot of mods to it without knowing the results lol. For the sides I put a big piece of sheet metal to cover from the top to the bottom. That piece extend from the arc of the quarter back to the rear roll pan, covering the horizonal line and the hole for the rear bumper all at once. This will give it a nice round look if you stand from the back. Again I used lots of fiberglass mat and resin to fill up all the gaps, dimples etc. Then grind, grind and fill with bondo and sand sand and sand. I used something called "side spats" on the bottom of the rear rockers to compliment my side skirt. I think it will look find without the side spats if you don't have the side skirts. Try it and let me know how it turns out. Good luck Vinh Quote Link to comment Share on other sites More sharing options...
DavyZ Posted January 28, 2007 Share Posted January 28, 2007 Vihn, I'm glad you spoke up in the thread. I was trying to remember the chap who had the yellow ZX with a great shaved back end--it was your car! Nice work on that car Davy Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted January 28, 2007 Share Posted January 28, 2007 DavyZ, haha I am no Jap. I am VietNamese btw. Yup what a coincident. I finished my car at the end of 1997 and then the C5 came out. The butt of my car looks a little bit like the C5 rear. Did anybody reallize that? hehe PS. I got those Riken rims from Ross back then.. lol .. and he still remember me now Quote Link to comment Share on other sites More sharing options...
DavyZ Posted January 28, 2007 Share Posted January 28, 2007 VinhZXT said: DavyZ,haha I am no Jap. I am VietNamese btw. Haha, no no. "Chap" means "fellow" or "gentleman" ---it's a British word more or less. Davy Quote Link to comment Share on other sites More sharing options...
woodboxer Posted January 28, 2007 Share Posted January 28, 2007 VinhZXT said: Woodboxer,Sorry I didn't take any picture while I was doing the rear on my 81. That was my first Z that I made a lot of mods to it without knowing the results lol. For the sides I put a big piece of sheet metal to cover from the top to the bottom. That piece extend from the arc of the quarter back to the rear roll pan, covering the horizonal line and the hole for the rear bumper all at once. This will give it a nice round look if you stand from the back. Again I used lots of fiberglass mat and resin to fill up all the gaps, dimples etc. Then grind, grind and fill with bondo and sand sand and sand. I used something called "side spats" on the bottom of the rear rockers to compliment my side skirt. I think it will look find without the side spats if you don't have the side skirts. Try it and let me know how it turns out. Good luck Vinh So Vinh what are side skirts and where did you get them? btw were did you get your front and side kits and how much would something like that cost. I will keep you informed when I get back to work on it , i am working night and day right now, I am hoping to get back at it next month. later bob Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted January 28, 2007 Share Posted January 28, 2007 DavyZ, Oh my bad. The "CH" in Vietnamese pronouce like "J". Bob, The side skirts I got from Jim Cook Racing. The front is the MSA type 2 front spoiler which I modified the hell out of it. The JCR side skirts are not the same as the MSA type 2 side skirts. I don't think they make them any more. I see them in the catalog but when I order them MSA sent me the wrong one. You can see I molded everything into the car. Believe it or not after 9 years everything is still holding up pretty good. No cracks. I guess I did a good job with the fiber glass lol. Check out the other thread about the 3 piece spoiler. I have some info in there how to modify the front MSA spoiler to look better. Good luck. Vinh Quote Link to comment Share on other sites More sharing options...
New2TheZ2006 Posted March 4, 2007 Share Posted March 4, 2007 Best I came up with is this. Shave the bumper, then cut the brackets behind the skirt and mount a cross bar behind the skirt on the cut / reduced brackets, so now you have "a hidden bumper" it still protects the fuel tank and can be pointed out to any officers so inclined to inquire. Quote Link to comment Share on other sites More sharing options...
New2TheZ2006 Posted March 4, 2007 Share Posted March 4, 2007 LOOK PHIL< I GOT NEW PAINT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! <---------------- only $236 wow, great price for a ppg two stage right now me needs info for rims, so I can get fitment right. Quote Link to comment Share on other sites More sharing options...
woodboxer Posted March 4, 2007 Share Posted March 4, 2007 well my plan is to install a steel channel and cover it , I think I can do it , I have been super busy so haven't had time to do ay work, I am hoping to get back at it within the next 2 weeks , if I do I will post some pics then, I know there is a lot more to do to it than the earlier models but I have to work with what I have oh well , later bob Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 5, 2007 Share Posted March 5, 2007 New2TheZ2006 said: LOOK PHIL< I GOT NEW PAINT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! <---------------- only $236 wow, great price for a ppg two stage right now me needs info for rims, so I can get fitment right. looks good. Quote Link to comment Share on other sites More sharing options...
bschiltz Posted March 5, 2007 Share Posted March 5, 2007 DavyZ said: Vihn, I'm glad you spoke up in the thread. I was trying to remember the chap who had the yellow ZX with a great shaved back end--it was your car! Nice work on that car Davy Nice! That'd look good with some ZG:wink: Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted March 5, 2007 Share Posted March 5, 2007 The 280ZXs are not good looking with flares unless you flare the whole fender IMO. When I build this car I thought about puting flares on it also and I looked into the Kaminari full fender flare kits. They were too expensive and their design were not 100% either. The Kaminari full fender kits didn't take care of the obvious ugliness of the whole car and that is the 2 bumpers. So I didn't go with it. Quote Link to comment Share on other sites More sharing options...
