BayAreaZT Posted December 19, 2006 Share Posted December 19, 2006 First, I have not opened my diff yet to even verify I have a Z31 LSD but it is a 3.70:1 and it does have the finned cover. I bought the car with it installed and I know one of the previous owners did install one. When I jack up the back and spin one of the wheels, the other one does not move at all. After reading some older posts, I should have checked turning the driveshaft too but I didn't do that test yet. Is this a normal symptom of the clutches going bad? If they are bad, will I get any use out of the LSD or is it just an open diff now. I skimmed through the shimming thread but I'll have to go back and read it again to fully understand whats going on. Also, if the fluids were changed but no LSD additive was added, would this cause any problems? Quote Link to comment Share on other sites More sharing options...
naviathan Posted December 19, 2006 Share Posted December 19, 2006 If it's a 300ZX diff it should have a Viscous LSD which uses motion transfer through liquid. Given the slow speed at which you can spin the tire by hand it wouldn't have enough momentum to turn the other side. No worries. SEE HERE FOR MORE INFO ON VISCOUS LSD Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 19, 2006 Share Posted December 19, 2006 If it's a 300ZX diff it should have a Viscous LSD which uses motion transfer through liquid. Given the slow speed at which you can spin the tire by hand it wouldn't have enough momentum to turn the other side. No worries. SEE HERE FOR MORE INFO ON VISCOUS LSD Huh? If it has a viscious in it, I'd be surprised. Those are very rare. Its most likely a CLSD if its a LSD at all... Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted December 19, 2006 Author Share Posted December 19, 2006 It's not viscous. I'm not using the shiro CVs. Quote Link to comment Share on other sites More sharing options...
naviathan Posted December 19, 2006 Share Posted December 19, 2006 Huh? If it has a viscious in it, I'd be surprised. Those are very rare. Its most likely a CLSD if its a LSD at all... I wasn't aware the 300ZX used a clutch type LSD. I only remember there being the open diff and the VLSD from the Shiro and turbo models. In any case if the clutches are going bad the diff fluid will be dark grey or black from the wear. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 19, 2006 Share Posted December 19, 2006 The 87-89 turbos used a CLSD. Only the 88 SS used the VLSD. Quote Link to comment Share on other sites More sharing options...
naviathan Posted December 19, 2006 Share Posted December 19, 2006 Got it. I wasn't aware of that as I don't own a 300ZX, but that's good info to have. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 19, 2006 Share Posted December 19, 2006 If you turned one CV and the other did not rotate then the unit must have been spinning the driveshaft. In either case, this is an indication of a busted LSD. Probably just needs new clutches. Are you sure the E-Brake wasn't sticking? How much resistance was there to turning? The diff could just have a really weak breakaway setting though. Try holding a cv in place while turning the driveshaft. You should not be able to turn the driveshaft. If it has gone bad, you basically have an open diff. You could easily check this by doing a burnout/peel out too btw. Just check the rubber patches. You should be able to feel it too. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted December 19, 2006 Author Share Posted December 19, 2006 I'll do the good 'ol burnout test then drain the fluid and see how it looks. Quote Link to comment Share on other sites More sharing options...
