zgeezer Posted January 4, 2007 Share Posted January 4, 2007 Did all 300 turbo LSDs come with the finned aluminum inspection cover? I've located a 300 turbo with manual transmission, w/o wheels, sitting on the ground in my local pick a part. Standard steel inspection cover, but the label on the door states this is a 1987 vehicle. Is there any VIN code that would tell me if this has the LSD. This car is right ON and IN the muck: there is no way I can turn a wheel without digging it out and having it lifted with a fork lift. Is it likely to worth the effort. g Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted January 4, 2007 Share Posted January 4, 2007 87 300zxt's before the 5th month of the year (May) I believe, did not come with LSD's. Remove the cover to be sure. Quote Link to comment Share on other sites More sharing options...
evildky Posted January 5, 2007 Share Posted January 5, 2007 it should have the finned cover if it's the stock LSD als verify the vin starte JN1CZ that C means it's a turbomodel and not just a car someone swapped Quote Link to comment Share on other sites More sharing options...
Gollum Posted January 5, 2007 Share Posted January 5, 2007 in my experience anything that's POSSIBLY a R200 CLSD is worth the effort. Go find out if it's LSD, and pull it if it is. Even if you don't have a use for it. If it's LSD it will have the finned cover, and i've personally never seen a non LSD with a finned cover (though i'm not saying they're not out there). Once it's out just crack it open and take a look-see. Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted January 9, 2007 Share Posted January 9, 2007 Lots of non LSD's with finned covers. 1986+ years. Becareful. Scott. Quote Link to comment Share on other sites More sharing options...
Benedict Posted January 10, 2007 Share Posted January 10, 2007 only 87 turbos made after 04/87 had LSD from the factory only LSD's had the finned cover but of course buyer beware... also note... the 88 SS model came with a VLSD and unique half shafts similar to those found in the S-chassis, Z32, etc... Quote Link to comment Share on other sites More sharing options...
