Careless Posted February 23, 2007 Share Posted February 23, 2007 im actually quite scared by those pics. LOL yowza Quote Link to comment Share on other sites More sharing options...
Racin_Jason Posted February 26, 2007 Share Posted February 26, 2007 Offset is 35mm, I have 10mm worth of spacer and rotor hat. So if it was on a stock Z drum a 25mm would be the same. Ya, 2.5" x 8" CO's. It fits but it is tight. Had to trim a little on the coil over sleeve and colar. They don't stick out so much with a little camber. I am at 1/4* neg in the pics. Fronts are 17x8 25mm with a 235/45 tire. I did run a 245 at one time but Toyo doesn't make RA1's in a 245. First off thanks alot for the time youve taken to answer my questions. I am currently trying to pick new wheels and tires (again) for my V8Z and this info helps me an awful lot. OK I wanted to clear this with you. You stated your rears are 9" wide and (with stock Z hubs/brakes) the offset would be 25mm. By my math a 9" wheel (10" bead-to-bead) with 25mm offset would have a backspace of 6"...and this clears the strut tube? I thought 5" was the usual max on coilover cars with 5.5" being a rarity. So your fronts are 8" wide with 25mm offset..which would be 5.5" backspace in the front. I also thought that was too much. I am looking to get the max contact patch on the ground and your combo looks to be ideal. I just want to make sure Im clear on your backspacing and sizes before I use it for reference on a purchase for my Z. I have stock 71 hubs and brakes. I also have coilovers with 2.5" springs but my springs are 10". Im willing to go 8" in the rear to gain a 275 though Im hoping Ill be able to fit a 235 or 245 in the front with the 10" spring. But with my stock hubs you are saying a 6" rear and 5.5" front backspace will fit with 8" springs eh? Jason Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 26, 2007 Author Share Posted February 26, 2007 On the fronts you'll have no problems with a 10" spring and a 245. It's just the rear. My front hubs also stick out (I think it was 10 or 12mm) more than stock Z hubs, it was have as much of the difference as a Z31 hub. You would have to run less offset in the front than 25mm. I could get away with a 15mm easy, so a 5mm or zero would work for S30 hubs. On the rear, I have a hat that is .100 thicker than the stock drum and a spacer that is .315" = 10.4mm - 35mm offset You would need a 24.5mm wheel to get the same wheel placement with drums and no spacer. If you had a little more, I know 27mm is common, you could add a small spacer. If you run a 16" wheel you would need to move it out board a little further a few mm to clear the strut tube. Quote Link to comment Share on other sites More sharing options...
buZy Posted February 26, 2007 Share Posted February 26, 2007 Looks great Clifton, but how do you keep the tires from destroying your fenders? Quote Link to comment Share on other sites More sharing options...
Project Z Posted September 1, 2009 Share Posted September 1, 2009 Too bad I only have 4 thumbs in total. You need 10 thumbs up! Quote Link to comment Share on other sites More sharing options...
