GOTHALOSISM Posted February 22, 2007 Share Posted February 22, 2007 my external lights are not working bad switch i think. Is this a feasable solution to work temp until i get a new switch? Quote Link to comment Share on other sites More sharing options...
gjc5500 Posted February 22, 2007 Share Posted February 22, 2007 it woudl work. depending on the actual set up mite not be a good thing. i was plaing on doing this but drawing power from the ignition hot switch so i CAN NOT leave my lights on. Quote Link to comment Share on other sites More sharing options...
Hartspank Posted February 22, 2007 Share Posted February 22, 2007 Mine is rigged up the same way. It's kind of cool 'cuz you can run with no tail lights. Works good for runnin' moonshine through Chickasaw county....YEEHAW!! Quote Link to comment Share on other sites More sharing options...
Paz8 Posted February 22, 2007 Share Posted February 22, 2007 Your diagram will work , but what about high beams? Fix your stock set up, there is a relay in the relay box that controls high/low beam, looking at the box from the passengers side fender it is the left relay towards the engine. Check the connector under the dash by the steering wheel, to see if it is burned or dirty, up front check for a good clean ground connection for the head lights. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted February 24, 2007 Author Share Posted February 24, 2007 Yeah Checked All Of The Connectors And Fuses. I Cleaned Them And Added Dielectric Greese. I Never Have To Use My High Beams Living In Las Vegas. Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 24, 2007 Share Posted February 24, 2007 Just add a switched power and ground to the relay. As you have in the fig. If that dosn't work you know the problem is from there on. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted February 26, 2007 Author Share Posted February 26, 2007 yup got them working teh wiring harness is bad so they are not getting power or good ground. Routed power and ground to teh side markers (getting shaved off any how) Quote Link to comment Share on other sites More sharing options...
