dapiper Posted September 6, 2010 Share Posted September 6, 2010 On 10/20/2008 at 4:48 PM, 1 fast z said: Can you get different cogs for different ratios? Yes and here they are: Blue 18 tooth 3.72 diff White 19 tooth 3.90 diff Red 20 tooth Purple 21 tooth Orange 22 tooth P/N 32702-F61xx where xx = no. teeth I may have gotten the last white one. Link to comment Share on other sites More sharing options...
Hybrid240z Posted September 8, 2010 Share Posted September 8, 2010 (edited) On 9/6/2010 at 2:54 AM, dapiper said: Yes and here they are: Blue 18 tooth 3.72 diff White 19 tooth 3.90 diff Red 20 tooth Purple 21 tooth Orange 22 tooth P/N 32702-F61xx where xx = no. teeth I may have gotten the last white one. Are these part numbers for the complete pinion assemblies or just the cogs. I went to the dealer and tried to purchase a 32702-02G17 pinion assembly and a 32702-F6118 (for a 3.7 diff) and they quoted me around $40 for each. I knew the 32702-02G17 number was the pinion assembly, but I though the 32702-F6118 was just an 18 tooth cog that I could swap out on the 32702-02G17 pinion assembly. So i'm thinking that the 32702-F6118 is a complete pinion assembly with an 18 tooth cog mounted on it already. dapiper, can you or someone else verify that this is correct so I can order the correct pinion assembly. Thanks. Edited September 8, 2010 by Hybrid240z Link to comment Share on other sites More sharing options...
vega Posted October 24, 2010 Share Posted October 24, 2010 You guys are going above my head with the cogs and gear ratio thing- can you guys offer a less vague explanation to what you are referring to exactly? Link to comment Share on other sites More sharing options...
ktm Posted October 24, 2010 Share Posted October 24, 2010 The speedometer pinion needs to have the correct cog/gear that matches the gearing of the differential for the speedometer to read correctly. Take the speedometer pinion assembly out of the transmission and you'll see that it has a colored cog/gear on the end of it. Each color corresponds to a differential ratio as dapiper posted. You can swap out these cogs/gears to match your differential and have your speedometer read correctly. Link to comment Share on other sites More sharing options...
vega Posted November 20, 2010 Share Posted November 20, 2010 that makes sense Link to comment Share on other sites More sharing options...
