j_eremy Posted March 13, 2007 Share Posted March 13, 2007 Ok, first off thanks for all the information, links and insight. I am going to make my own motormounts,now that I have the diminsions. although, I dont want to make my own driver side exhaust manifold. is there a company who sells a block hugger header for the zx swap? also I have a question about gearing, I currently have a 4.11 in my zx, with a borg warner t5 out of a Iroc will my gearing be to steep for freeway driving,. the engine is cammed, 2-6k power pand. or should I put my original 3.90 back in.. thanks Jeremy. Quote Link to comment Share on other sites More sharing options...
Z-8 Posted March 13, 2007 Share Posted March 13, 2007 I'm doing a ZX swap myself here in San Diego, and the first thing I did was use the search function for headers. The 2 main problems being of course the steering box being in the way, and ZX's were first made in '79, making them a smog issue. Just 2 "little" obstacles. Now duck, and look out for flames. Quote Link to comment Share on other sites More sharing options...
bschiltz Posted March 14, 2007 Share Posted March 14, 2007 When you mention dimentions for mounts, are you refering to the JTR mounts? If so I'd caution you to make sure you are looking at the 280ZX mounts and not S30 mounts as they are very different. Quote Link to comment Share on other sites More sharing options...
dustin280zx Posted March 14, 2007 Share Posted March 14, 2007 you will have to get the headers for mounts your copying off of. if your doing jtr mounts, jtr sells headers for the zx. Quote Link to comment Share on other sites More sharing options...
j_eremy Posted March 14, 2007 Author Share Posted March 14, 2007 Ok the motor mounts I am making are a copy of the MSA mounts. going to use their headers. also any info on my gearing setup? I think it will be fine but I have never ran this setup on the highway. the rear end I have in my z is a 4.11 and I am using a 5 speed out of a Iroc am wondering in 5th gear if it will still be to low for freeway driving, or if I should use my 3.90, which came stock. thanks for the info. my came range is 2-6k. its a erson cam. Quote Link to comment Share on other sites More sharing options...
bschiltz Posted March 14, 2007 Share Posted March 14, 2007 I don't know about the gearing in T-5s, sorry. The only thing I can offer is try to find the casting numbers on the tranny and look on google to find the gear ratio, then figure out your RPMs from there (using tire size etc.) Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted March 14, 2007 Share Posted March 14, 2007 This is just a shameless plug for JTR ZX V8 mounts. When using the MSA mounts, the shifter will be about 2" forward of the stock shifter hole. With the JTR mounts, the shifter will be further rearward, so less cutting of the shifter hole is required, and the shifter position will appear closer to stock. When using the power steering box (non-rack and pinion), the 1982-1992 Camaro exhaust manifold can be used on the driver's side. When using the rack and pinion steering (manual or power assist), I know of no headers, other than ours, that will fit. I would avoid the 3.9 gears and try to find the 3.54 R-200. Overdrive on the V8 Camaro T5 is normally .73, but some models came with .63 overdrive. Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted March 15, 2007 Share Posted March 15, 2007 Will your headers fit with the MSA mounts? Just curious. Quote Link to comment Share on other sites More sharing options...
Paz8 Posted March 15, 2007 Share Posted March 15, 2007 This topic has been gone over again and again, read Mike's post carefully, it is the way it is, there are NO magic solutions, If you mix and match parts for the swap you'll end up spending more in the long run on parts that won't fit, alot of wasted time also. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted March 15, 2007 Share Posted March 15, 2007 I'd have to suggest you go w/ Mike JTR's stuff. It's cheaper than what you can do it yourself for if you price materials and your time / equipment, and it's right the first time. Quote Link to comment Share on other sites More sharing options...
danc Posted March 16, 2007 Share Posted March 16, 2007 I made a post dated May 17 2001 04:26 PM Subject: ZX SBC using MSA mounts. (just checked and it's still there). There are some lessons learned on various piece/parts for an 83 that has Power R&P; including the driver's side hedder. If you have any other questions, I'd be happy to provide any help I can. My car has been running now for 6 years, is reliable and runs in the 11s. There are also a few photos on the "Album".. Good luck.. Quote Link to comment Share on other sites More sharing options...
