Gollum Posted June 22, 2007 Share Posted June 22, 2007 I can't stop thinking about the slant mounted intercooler on SR240z's SR setup. Wouldn't it make sense to duct the system so that air would HAVE to go through the radiator, then build a duct into the engine bay making the 90 degree bend upwards and then having air extraction slots on the hood above the IC? It seems to me (granted i'm stupid sometimes) that as long as you're airflow is sealed between the radiator and IC they don't need to be right up against each other. If it's not a sealed system after the radiator then I can totally see wanting the IC right up against it. Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted June 22, 2007 Share Posted June 22, 2007 On my last car I sealed the IC to the AC condenser using 2"x2" air conditioner foam weather stripping (from HD). It stuffed nicely in the gap and compressed down to make a very good seal. I also used it to seal the radiator to the condenser. - Greg - Quote Link to comment Share on other sites More sharing options...
zgeezer Posted July 9, 2007 Share Posted July 9, 2007 Stealing from another thread, it might be worth the effort to mock up the front setup from the early factory Works Zs. I really like that look. I notice that this car had two hood vents on either side of the hood's center line with, what appears to be a small deflector strip on the leading edge. If this works, then one might think that the '73 "competition hood scoop" sold by Datsun to cure overheating might have some real aero advantage. The installation instructions required cutting a hole about 18" long and eight inches wide in the hood and then covering it with this fiberglas cover. Note that the air exits out the sides of the "scoop". G Quote Link to comment Share on other sites More sharing options...
jknc90 Posted July 9, 2007 Share Posted July 9, 2007 I would love to have that hood scoop tested b/c I'm putting one on my car and I'm curious as to how effective it is aero wise jon Quote Link to comment Share on other sites More sharing options...
