Devil-Z Posted May 14, 2007 Share Posted May 14, 2007 I remembered that a few years ago I had seen an article on a shop in England that was building a very small V8 from two Suzuki Hayabusa 1300cc motors. It used the Suzuki heads with a V block that the shop had cast for them. I looked it up and it looks like they are in production now. This thing would be perfect in a Z! It's supposed to be small, Very light weight, will rev to 10,000 RPM and makes 330 HP! What more could you ask for! http://www.radicalextremesportscars.com/range/sr8/sr8.php Quote Link to comment Share on other sites More sharing options...
Devil-Z Posted May 14, 2007 Author Share Posted May 14, 2007 Check out this video. http://www.radicalextremesportscars.com/news_folder/dvd2005/sr8.php Quote Link to comment Share on other sites More sharing options...
jdarkme Posted May 14, 2007 Share Posted May 14, 2007 There's also the RST-V8 http://www.rst-v8.co.uk/ It's basically the same as the above, it revs to 10,200 rpm, produces around 360hp and 190 lbs/ft of torque and weighs about 163 pounds. These types of engines are really cool and sound great but they're really expensive, I believe they're around $30,000. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted May 15, 2007 Share Posted May 15, 2007 Would the low torque numbers hurt streetability, OR, would getting into the upper power band make up for it? Maybe 1, 2 very low gears to get you off the line the rest could be a bit more spaced out. Also, the Z is alot heavier than the cars they picture installing them into on that site. Quote Link to comment Share on other sites More sharing options...
Pete84 Posted May 15, 2007 Share Posted May 15, 2007 http://en.wikipedia.org/wiki/Nordschleife_fastest_lap_times#Current_Miscellaneous_Lap_Records:_OEM_Passenger_Vehicles_.26_Sport_Racers The Radical has the fastest 'ring lap time Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted May 15, 2007 Share Posted May 15, 2007 same engine from the DP1 and the atom, referenced from dpcars.net as posted in the mclaren thread Quote Link to comment Share on other sites More sharing options...
jdarkme Posted May 15, 2007 Share Posted May 15, 2007 Would the low torque numbers hurt streetability, OR, would getting into the upper power band make up for it? Maybe 1, 2 very low gears to get you off the line the rest could be a bit more spaced out. Also, the Z is alot heavier than the cars they picture installing them into on that site. With a 4.63 diff or something like that I'm guessing it wouldn't be too bad. But yeah, the Z is quite a bit heavier than the other cars even if you do lose some 250lbs (guestimate) with the swap. But you could always just supercharge or turbocharge the motor, especially because someone with the money to do the swap would probably also have enough money to make it more powerful. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted May 23, 2007 Share Posted May 23, 2007 I thought the atom used honda and dodge 4-bangers? Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted May 23, 2007 Share Posted May 23, 2007 http://www.dpcars.net/atom/index.htm Quote Link to comment Share on other sites More sharing options...
Pete84 Posted May 23, 2007 Share Posted May 23, 2007 I thought the atom used honda and dodge 4-bangers? The Atom uses Honda K20's in the UK and Ecotec supercharged engines in the US. http://en.wikipedia.org/wiki/Ariel_Atom Quote Link to comment Share on other sites More sharing options...
