just ordered my megasquirt
MaTTSuN
i just ordered it the other day from DIY
Matt Cramer has already contacted me and asked what my setup is like
im running the 81 280zx turbo motor and was wondering what the crank pick-up was Optical...magnetic.. im not sure but im sure my MS will run better if i have this info
ive read that the 81 CAS will work with 82-83 ECU's so i guess its the same signal..
so excited to get squirting
:Matt
yeah im getting sick of "tuning" and not getting anywhere. at least when i change something it will make a diff
very excited a little nervous cant wait to post some video of drifting and donuts mmmmmmm donuts bwahahahaha
as long as i make power ill be happy since ive never felt the L28 under boost my n/a pulled pretty good but boost must be amazing tourqs haha
is the signal from the 81 cas the same as the later models with the cas in the dizzy?
Matt cramer from diy is asking my setup but from what i see its the same hook up either way... since they both give the same signal? is this right
muha ha ha ha ha, boost is like, ummm? crack! VERY addictive!! just a little bit more,.....ok, just a little more......mmmmm.... just a little more!!!! WOW 8 psi feels great, holy moly 10 psi feels awsome, lick my craper!! 15 psi is unbelievable, Oh my GOD!! 20 psi is the magic number, I have wood in my pants!!
something like that?
just wondering if i should install my intercooler while im at it?
its 13 x 8 x 3 i think its off a 626 but i swapped my end tanks and put 3inch in and outs on them will that help or hurt for my goals about 250hp..
I would say yes if it is a good build quality. 250HP no problem. If you go much more than that >300whp, or more than 15psi boost, you might think bigger. You could also make some duct work to feed air to the intercooler which would be even better and make that size good enough for even more power. I would use it. You could always upgrade to a similar one and keep the existing plumbing.
See this chart for sizing and HP:
http://www.racetep.com/tneticatoaic.htm
SOLD ill do it haha i just filled it up with water doesnt leak should test it a bit more.. but ill get some plumbing and put the bad boy on
i got my instructor at TIG school to do it on my last day haha i just watched
i hooked it up to my shop vac doesnt seem to slow it down at all when i blow threw it so excited!
whats the most boost i can run with the stock injectors? might have to add an extra one or 2
I GOT MY MS TODAY so excited to put it in
its allot smaller then i thought
i think i might put it and the relay board in the glove compartment
ill take pics along the way
hope i can have it running by next week
had a few min to map out where i want everything
i think i might put the ECU right under the steering wheel
i dont have that plastic cover that covers all the electronics so ill have to make a new one anyways
seems to be allot of room for my legs and what not
and then mount my relay board under my glove box
my 78 has plastic trim that hangs down a bit under the glove box and u wont be able to see it but it will be easy to access and mount
any thoughts?
id like to keep the relay board out of the engine bay
