MaTTSuN Posted May 19, 2007 Share Posted May 19, 2007 i just ordered it the other day from DIY Matt Cramer has already contacted me and asked what my setup is like im running the 81 280zx turbo motor and was wondering what the crank pick-up was Optical...magnetic.. im not sure but im sure my MS will run better if i have this info ive read that the 81 CAS will work with 82-83 ECU's so i guess its the same signal.. so excited to get squirting :Matt Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 19, 2007 Share Posted May 19, 2007 Congrats. I am about 3 months ahead of you and I am about to finish the wiring. I should be turning the key within a few days. Next comes the debugging and tuning. Start reading the mega manual NOW. Good luck. Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 19, 2007 Author Share Posted May 19, 2007 thanks man wow quick reply how long did it take you to wire up? im going to devote a weekend to it when i get it so like 20 hours maybe more haha see were i end up Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted May 20, 2007 Share Posted May 20, 2007 I think there has been an addition to the MS install thread about using the CAS from the '81... I myself am gonna put magnets on the back of my dampner and use a hall sensor and GXR coils.... Quote Link to comment Share on other sites More sharing options...
260zturbo Posted May 20, 2007 Share Posted May 20, 2007 congrats, headachs will come but it will all pay off. Quote Link to comment Share on other sites More sharing options...
big-phil Posted May 20, 2007 Share Posted May 20, 2007 congrats, I think you'll really like it. Um...invert the spark signal......no more than about a 3.0 running dwell.......I think thats about all the major screw ups I did. lol Read the online manual! http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 21, 2007 Author Share Posted May 21, 2007 yeah im getting sick of "tuning" and not getting anywhere. at least when i change something it will make a diff very excited a little nervous cant wait to post some video of drifting and donuts mmmmmmm donuts bwahahahaha as long as i make power ill be happy since ive never felt the L28 under boost my n/a pulled pretty good but boost must be amazing tourqs haha Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 21, 2007 Share Posted May 21, 2007 Ahhh the boosted L28 yes it is addicting. The faster you go, the harder it pulls! Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 21, 2007 Author Share Posted May 21, 2007 and the harder it pulls the faster it goes!! ha Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 21, 2007 Share Posted May 21, 2007 I think there has been an addition to the MS install thread about using the CAS from the '81... yes there was an addition from Tony D. Just look through, it is highlighted in a quote box. Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 21, 2007 Author Share Posted May 21, 2007 is the signal from the 81 cas the same as the later models with the cas in the dizzy? Matt cramer from diy is asking my setup but from what i see its the same hook up either way... since they both give the same signal? is this right Quote Link to comment Share on other sites More sharing options...
big-phil Posted May 22, 2007 Share Posted May 22, 2007 ive never felt the L28 under boost muha ha ha ha ha, boost is like, ummm? crack! VERY addictive!! just a little bit more,.....ok, just a little more......mmmmm.... just a little more!!!! WOW 8 psi feels great, holy moly 10 psi feels awsome, lick my craper!! 15 psi is unbelievable, Oh my GOD!! 20 psi is the magic number, I have wood in my pants!! something like that? Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 22, 2007 Author Share Posted May 22, 2007 just wondering if i should install my intercooler while im at it? its 13 x 8 x 3 i think its off a 626 but i swapped my end tanks and put 3inch in and outs on them will that help or hurt for my goals about 250hp.. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 22, 2007 Share Posted May 22, 2007 Intercool it now! You are already diseased. Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 22, 2007 Author Share Posted May 22, 2007 ok but is the intercooler big enuf? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 22, 2007 Share Posted May 22, 2007 I would say yes if it is a good build quality. 250HP no problem. If you go much more than that >300whp, or more than 15psi boost, you might think bigger. You could also make some duct work to feed air to the intercooler which would be even better and make that size good enough for even more power. I would use it. You could always upgrade to a similar one and keep the existing plumbing. See this chart for sizing and HP: http://www.racetep.com/tneticatoaic.htm Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 22, 2007 Author Share Posted May 22, 2007 SOLD ill do it haha i just filled it up with water doesnt leak should test it a bit more.. but ill get some plumbing and put the bad boy on i got my instructor at TIG school to do it on my last day haha i just watched i hooked it up to my shop vac doesnt seem to slow it down at all when i blow threw it so excited! whats the most boost i can run with the stock injectors? might have to add an extra one or 2 Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted May 28, 2007 Author Share Posted May 28, 2007 I GOT MY MS TODAY so excited to put it in its allot smaller then i thought i think i might put it and the relay board in the glove compartment ill take pics along the way hope i can have it running by next week Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted June 3, 2007 Author Share Posted June 3, 2007 had a few min to map out where i want everything i think i might put the ECU right under the steering wheel i dont have that plastic cover that covers all the electronics so ill have to make a new one anyways seems to be allot of room for my legs and what not and then mount my relay board under my glove box my 78 has plastic trim that hangs down a bit under the glove box and u wont be able to see it but it will be easy to access and mount any thoughts? id like to keep the relay board out of the engine bay Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted June 7, 2007 Author Share Posted June 7, 2007 ok i got all my wirering sorted now i have to install as soon as the flood warning passes and my car is not under water ill be putting this badboy together Quote Link to comment Share on other sites More sharing options...
