gigitty Posted August 4, 2009 Share Posted August 4, 2009 please email me also h00p1075@aol.com Link to comment Share on other sites More sharing options...
smoorenc Posted August 5, 2009 Share Posted August 5, 2009 I put them up on my personal website to help so they don't need to be emailed. Just click and download. Other files (in second link) are also available. I was hoping that his would help. http://www.4moores.com/280z/files/JCI Install Update 1.doc more ls1 files: http://www.4moores.com/280z/files Link to comment Share on other sites More sharing options...
hachikid Posted August 14, 2009 Share Posted August 14, 2009 wow, thanks a lot! I'm actually doing research on how to do the swap, and this will help a WHOLE lot! thank you for doing this! Joseph. Link to comment Share on other sites More sharing options...
Old Man Posted September 16, 2009 Share Posted September 16, 2009 Hey Grenade 300, I noticed that you had used a fuel cell with your conversion. Was this a Summit Racing unit? What model? Also you mentioned a EZ Wire harness kit. Can you provide a little direction there also. Thanks for all the help you have already provided. Link to comment Share on other sites More sharing options...
Guest Grenade300 Posted September 22, 2009 Share Posted September 22, 2009 I cannot provide too much info on the wiring harness. There is too much info for me to convey in a post (at the risk of sounding like a snobby jerk). I don't have tha part number off hand (middle of moving to Germany right now) but I used the 16 gal polyureuothane fuel cell from Summit Racing... I do not recommend this unit because the fuel runs away from the pick-up under hard braking with less than 1/3 tank. If I had to do it again; I would use a tank without a sump and weld my own sump on with 3 small holes drilled between the tank and sump to prevent the fuel from running away from the pick-up. Link to comment Share on other sites More sharing options...
Old Man Posted September 23, 2009 Share Posted September 23, 2009 Hey, Thanks for the reply. I plan to begin my conversion in the month of October. The more I read it seems that most coversions are leaning towards the sump idea. This is my frist Z car, so everything is new territory. Good luck with your move and take care. Link to comment Share on other sites More sharing options...
DarthZ Posted October 28, 2009 Share Posted October 28, 2009 Hey guys, I was the lucky one that purchased Grenade300's car before he headed out to Germany. I have ton's of pics from his conversion work and can take new ones if there is something you need to see from a different angle. Grenade is still the knowledge source as I just got the car, but I may be able to help as well. The John's Cars kit used to install the motor and tranny where developed on my Dad's car (Phantom) several years ago, so I do know a bit about this. The install work and parts on this car are phenominal, but as Grenade said the fuel cell is an issue and the pump is LOUD! I have a solution I am working on for the tank and will post the info on it once complete. There is a trap door set up that can be worked in around the sump to prevent run off and if you have an aluminum tank you can have walls welded in accross the tank forming a grid pattern through it with holes at the bottom of each section to allow flow through, but prevent sloshing. No fuel sloshing = a less abrupt weight shift in cornering/braking and would limit the fuel from running away from the sump. I started a photobucket that I will start posting pics at. Just let me know if there is anything you want posted and I will try to assist. http://photobucket.com/DarthZ Link to comment Share on other sites More sharing options...
Phantom Posted October 29, 2009 Share Posted October 29, 2009 I notice a lot of discussion about fuel cells and I question the need - especially on the 280Z conversions. My car is running it's original tank and a single electric pump in the same location as the original one. The only time I've seen any starvation problems with it was when I had less than 1/8th tank and was going through some of the tight infield curves at Texas Motor Speedway. It also allows me to not worry about or smell fuel leaks/smells inside the car. I realize it means having to route the passenger side exhaust over to the drivers side but that also worked out well in my car. Link to comment Share on other sites More sharing options...
smoorenc Posted November 24, 2009 Share Posted November 24, 2009 I have some pics to add of the places where the tunnel "pounding" modification was required. Is it OK to add to the current DOC? Link to comment Share on other sites More sharing options...
team_infidel Posted November 25, 2009 Share Posted November 25, 2009 wow man good info, what year ls1 did you use, what was the donor car, read the whole document, i think i missed it. would it be pretty much the same for like a pontiac gto engine? Link to comment Share on other sites More sharing options...
DarthZ Posted November 25, 2009 Share Posted November 25, 2009 wow man good info, what year ls1 did you use, what was the donor car, read the whole document, i think i missed it. would it be pretty much the same for like a pontiac gto engine? I bought the car from Grenade300 and I am not sure how much he is still in the Z scene since he just went to Germany. Scott, let me know if it seems like:hijack: to you. The motor and tranny are out of a 2002 Camaro SS. Yes a GTO engine would be about the same. Make sure you buy from a reputable source and the engine comes with the original wiring harness and ECU. Link to comment Share on other sites More sharing options...
wajouba Posted November 26, 2009 Share Posted November 26, 2009 im having alot of trouble with my wiring I wish there is a DIY for it... so I can get some help... anyone found anything? Link to comment Share on other sites More sharing options...
drive185mph Posted December 3, 2009 Share Posted December 3, 2009 Hey man could you send me a copy? pretty please drive135mph@yahoo.com (not drive 185 mph like the screen name) thanks Link to comment Share on other sites More sharing options...
smoorenc Posted December 9, 2009 Share Posted December 9, 2009 I put them up on my personal website to help so they don't need to be emailed. Just click and download. Other files (in second link) are also available. I was hoping that his would help. http://www.4moores.com/280z/files/JCI Install Update 1.doc more ls1 files: http://www.4moores.com/280z/files __________________ Link to comment Share on other sites More sharing options...
smoorenc Posted December 20, 2009 Share Posted December 20, 2009 I just added a lot of LS1 diagrams in PDF that I got from other sources. I hope this helps some people out. http://www.4moores.com/280z/files Link to comment Share on other sites More sharing options...
smoorenc Posted December 23, 2009 Share Posted December 23, 2009 I added some pictures of the tunnel area's that needed modifying to the document. The pictures were absent from the original document. I am also in the process of adding the wiring changes that I am doing to the LS1 wiring harness. This way with pictures it might make it easier for others. http://www.4moores.com/280z/files/JCI Install Update 2.doc http://www.4moores.com/280z/files Link to comment Share on other sites More sharing options...
kenwood guy Posted April 4, 2010 Share Posted April 4, 2010 (edited) Great info man I have been looking for a post like this one!!! but I got a question did you buy the whole donor car or did you just buy the motor,trans and radiator pulled out all ready to go for you?? If so what else did you use external to these main parts?? Edited April 5, 2010 by kenwood guy Link to comment Share on other sites More sharing options...
duragg Posted December 1, 2010 Share Posted December 1, 2010 I could take all of these and make them into a PDF once and forever.... Or did somebody already offer this? Tj Link to comment Share on other sites More sharing options...
smoorenc Posted January 6, 2011 Share Posted January 6, 2011 Thanks for the idea. I uploaded it. http://www.4moores.com/280z/files/index.html Link to comment Share on other sites More sharing options...
jpmc86 Posted May 3, 2011 Share Posted May 3, 2011 Hi, when time permits, can you send a copy of your guide to : Hankporter@aol.com Thanks, John Link to comment Share on other sites More sharing options...
