i cant get anything right
ok, i had a hell of a squat problem when launching, i was on stock 240 struts and 280zx springs. i had to cut the hell out of my quarters to stop from tearing up the drag radials(275/50/15) so i installed non-adjustable tokico's and suspension technic(sp?) springs with a 1" drop. now the damn tires rub when i take a corner :mad: . will a sway bar cure this? the car does not have one (rear) and as far as i know the 240's did not come with one. if it will help then is there a kit?
thanks, shane
My Suspension Techniques bar comes with new risers for the back of the control arms. This puts the bar BEHIND the differential. Mine were a matched set from Summit Racing. The 73 240 DOES have the factory mounts to use the 260/280 rear bar but if your 72 is like mine, it does not. 275 50's are HUGE...
eh, the 345/25 20s i saw at work are HUGE, not saying they'd fit, but they're big. i work at UPS in toledo (we get all of tire rack's tires going to NE coast) btw...STOP BUYING TIRES NEW ENGLAND redface.gif !!! i mean jeez, 100-500+ a night, every night, since Oct. last year is a bit much. ever lift a mounted tire over your head to load all the way to the top of a semi-trailer? repeatedly? twak.gif
sorry, just got off work...but yea, i see some interesting tires.
DAW. you are a fountain of good information. Nezzie 76 had a ujoint hitting the rear sway bar on de-acceleration on his 280 V8 Z . The connecting rod bolts for the sway bar were too long on the slightly lowered Z causing one rod bolt to be bent. Regrettably, the sway bar was removed. I agree with your conclusion a sway bar helps to get around a corner fast even with the indepedant rear and behind the diff is a more logical place for the sway bar. Just one more modification to an endless number that I will do to my unfinished project
Hey DAW, I may have another set of the Suspension Techniques risers. My parts 240 (73) has a factory 280 rear bar, BUT at some point in time it had the ST setup and the risers are still there. If you aren't in a hurry (I've gotta do a roof on my house ASAP) and might be interested, let me know.
